Author Topic: Cb500F What have I gotten myself into??  (Read 22125 times)
Re: Cb500F What have I gotten myself into Build!
« Reply #25 on: March 27, 2014, 07:01:59 PM »
Found the shifter lever, send me your address and it's yours no charge.
Offline 2strokeTrush
  • Can you get that back together sonny?
« Reply #26 on: March 27, 2014, 07:40:08 PM »
Thanks for the help guys,  I would like to find a decent rear wheel soon. If anyone sees any let me know! Also, what does everyone think Air Filter wise?  Its going to need a new one.
« Last Edit: March 27, 2014, 07:47:24 PM by 2strokeTRush »
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
Online grcamna2
« Reply #27 on: March 27, 2014, 08:14:13 PM »
Tyler,
I myself would install a paper replacement(O.E. style)element into the stock airbox.
« Reply #28 on: March 28, 2014, 06:18:54 AM »
Tyler,
Alright thanks, Where do you recommend buying from?
Online grcamna2
« Reply #29 on: March 28, 2014, 06:48:26 AM »
I haven't looked lately but you might try an Emgo... I know they're are a few companies that make aftermarket air filters,but I haven't been buying any since I had my repair business.I like OE but they're expensive and tough to find.
« Reply #30 on: March 28, 2014, 09:22:30 AM »
Alright cool Ill look into that!
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #31 on: March 28, 2014, 10:34:21 AM »
That looks like a custom chopper type rim w/ a big fat 16" tire..,if it was me I'd go back to the stock 18" rear rim and tire.
Yeah I kinda hate it.  Could I run a Avon on that rim still?
You could but I wouldnt. Best route to go is buy a used rim/hub on here or ebay.
Or trade....if you can find a sucker...ha! The 18" rim will improve handling, 'nuff said.
What's the correct width for that bike?
I have a 185 x 18" rim in decent condition that I would part with for the low low college-guy discount price of "free" with free shipping on the sole condition that you promise me you will use it if I send it. I tried to look it up somewhat feebly and failed. See if you can find out from one of the smart guys here or elsewhere if this is the correct size and PM me your address if it's all a go. I may even have the old spokes and nipples from my 400 for this wheel - no idea if they're correct for your hub and it might be a terrible idea to reuse them, but if I have them and you want them I'll send them too.
I have a motorcycle problem.
Offline Mcwilliams570
« Reply #32 on: March 28, 2014, 10:41:27 AM »
I might have a rim for you too. I am about 50 miles from you in Wilmington De. I have a 72 cb500 parts bike just sitting around in my garage if you need any parts hit me up..
Matt
My CB550 project http://forums.sohc4.net/index.php?topic=101182.0
Project UFB Cb550 http://forums.sohc4.net/index.php?topic=112143.0
Like a 10 dollar hooker on Friday night its going to be ridden.
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
« Reply #33 on: March 28, 2014, 05:09:19 PM »
Matt
Thanks man, is it just the rim or is it the complete rear wheel?  And do you have a starter and horn?  Right now I'm thinking of those.
« Reply #34 on: March 28, 2014, 05:11:56 PM »
Thanks man thats really really nice of you!  Ill try and find out what the stock size is!
« Reply #35 on: March 28, 2014, 06:02:00 PM »
Matt
Its a complete rear wheel. I should have a horn and starter will check when I get home from work tomorrow.
Matt
1974 cb550
1975 cb550
2005 vmax
2009 vmax-sold
1981 gl500i
Offline NobleHops
« Reply #36 on: March 28, 2014, 06:40:54 PM »
What's wrong with your starter homes? Those are a lot easier to fix than it might seem. Check out my thread (sig) and see how I repaired mine. Complete rebuild kit including everything you might possibly need it $18, shipped.
BTW, Matt McWilliams, you kick ass.
N.
« Reply #37 on: March 29, 2014, 09:39:46 AM »
N.
Oh I have been following right along on that thread! ;D  I saw your rebuild and that pretty freakin sweet.  The PO said the starter never worked right and just pops when you hit the button.
Offline NobleHops
« Reply #38 on: March 29, 2014, 09:58:11 AM »
N.
What happens when you try it with a fully charged battery? First things to check are the connections to the solenoid, then from solenoid to the starter and the ground to the frame. Renew those connections with the battery disconnected, make sure they are all clean and tight (fine sandpaper and dielectric grease) and then try again. IF the battery is fully charged and you just hear a little clicking from the solenoid, that could be your culprit. Pull back the rubber hood, grab a big screwdriver and CAREFULLY bridge the two posts on top. DON't touch the metal of the screwdriver while you do this - you are connecting the starter directly to the battery momentarily when you do this and if you are touching the metal you will be sad. If the starter spins normally w hen you do this then the solenoid is your culprit.
If none of that makes any difference and the starter just makes odd noises or gets hot, then get into that. Remove the battery, remove the positive lead to the starter, remove the two bolts holding it in and wiggle it out - there's an oring on the shaft. Disassembly is pretty easy, just go slow and take pictures.
Do this in this order and you wont' chase your tail replacing good parts :-). And don't bother troubleshooting this with a weak battery. Fully charged battery first.
Report back!
« Reply #39 on: March 29, 2014, 09:46:06 PM »
N.
Report back!
Thanks for the tip on the starter.  Ill give that a go.  And when I hit the starter it just pops but ill try going direct across the solenoid like you mentioned.
« Reply #40 on: March 29, 2014, 09:52:52 PM »
Bad weather and work tied me up most of today, but got a little bit done on both bikes.  Soaking the tank in Vinegar has really started pulling the Rust out!  Ill post a picture in a few days of what it looks like ( Hopefully ) done!
Strained the first batch, this is not nearly as much as I got out.
This was clear at one point!
Petcock freed up with the soaking I guess!
Really hoping this week I can put gas in the tank an try running her again.  One question though-On the fuel line there is a little brass insert that pushes and holds the line into the Petcock and is inside the line.  Only one of my lines has this, so I can only plug one line into the tank.  My question is where can I find more of these?
Online grcamna2
« Reply #41 on: March 29, 2014, 10:03:05 PM »
2 stroke,
Tank work and Vinegar..."what have you gotten yourself into"  ;D
I hope you're able to cut that old fuel line where your old brass outlet tube from your petcock is because they're TOUGH to find.I've done mine by Not trying to remove the little brass tube w/ pliers,but using a razor knife and Carefully(don't cut your fingers !)slicing the old fuel line.. I learned a while back that you have to buy a complete petcock(new or used)just to get that little tube;it's a Precise fit.
« Reply #42 on: March 30, 2014, 06:06:28 AM »
2 stroke,
HAHA yeah not much of a update, just wanting to get this going!  Thanks for the tip on the fuel line.  Sucks I may have to buy a complete Petcock.  Guess the hunt is on!
« Reply #43 on: March 31, 2014, 09:27:11 AM »
Just ordered a new Petcock.  Noob question but how hard is it to replace?  Should i use any sealer when installing?  You can tell i have never touched one before ???
Online grcamna2
« Reply #44 on: March 31, 2014, 01:15:10 PM »
Tyler,
It should just take 1 or 2 jis(Japanese industrial standard)#3 phillips screws that screw into the tank,they can be accessed from inside the petcock.I hope you ordered a new OE petcock because they come w/ all the rubber seals & you install everything dry.Clean the tank where the petcock seal meets up w/ the tank so its smooth and will create a good seal,just make sure there's no more gas in it when you remove it  :o
« Reply #45 on: March 31, 2014, 01:43:47 PM »
The petcock is super easy to replace.  Make sure the tank is clean (no gas) as well as the bung.  You should use a petrol-resistant sealant (not teflon tape) to seal the threads of the bung and petcock so you don't get any leaks down the road.  Easy peasy.
« Reply #46 on: March 31, 2014, 07:12:57 PM »
[/quote]
Tyler,
Thanks guys, Ill let the tank soak until the new one comes in but its good to know its not going to be difficult.
« Reply #47 on: April 01, 2014, 11:06:59 AM »
Well today I decided to try and get a little work done on the bike as the weather was close to 60 outside.  Just for fun I started the bike to hear her run, afterwards I felt the pipes and number 3 was cold,  Leaving me to believe the Cylinder is not firing. What could be the cause of this?  Could it be as simple the points or am I in trouble?  Then I went to turn her on again and I have no power to the forward controls, No blinkers or turn signals, headlights or Dash lights.  But when I went direct across the starter it sparked.  SO the bike is getting power somewhere.  Think I popped a fuse?  Where do I check that, besides the fuse by the solenoid that was fine.  The carbs are in need of a cleanup, and the bike doesn't have a constant fuel source yet, and we were using a jump box, not the battery as it is shot.  Hoping these factors may have contributed. Basically I'm pretty upset, as last week I had a sort of running bike with electronics that worked.  Now Im SOL.   Pretty depressed as I was pretty excited about the bike being almost perfect.
Point are pretty dirty and greasy.
The front brakes have no pull in the lever it just pulls in an springs back out with no force whatsoever.  So I took off the MC cover
« Last Edit: April 01, 2014, 11:13:53 AM by 2strokeTRush »
Offline calj737
  • I refuse...
« Reply #48 on: April 01, 2014, 11:13:44 AM »
Let's see:
1. When you add brake fluid, you'll have to bleed the system. Careful with removing/opening the bleeder. Start soaking it in penetrating oil now, then replace it with a new one.
2. Fuses: left side, under side cover. Check them all.
3. Faulty electrics: could be a bad run/stop switch connection, connections behind headlight, lots of places. Troubleshoot the areas one-by-one and repair and grease all fittings. If in doubt, cut and solder on new connectors.
4. #3 cold - probably the plug cap. Check the fitting at the spark plug, and pull the plugs (keep them ordered) and compare them. Check for spark on that cylinder. Could be a bad wire connection to that plug only
Keep this in mind- you paid $500 and got a great bike; not a perfect bike. It's going to need some work and some elbow grease to make it reliable and safe. Do the 3,000 mile tune up on it. Make a list of things that need attention, and you'll get thru them quickly. Pull down the manual off this site and keep it for reference.
Also, make sure you adjust the valves, clean the points and double check all your bearings. Replace your fork oil too!
« Reply #49 on: April 01, 2014, 11:22:39 AM »
Let's see:
Thanks man. I know its gonna take some work just upsetting about it going downhill so quickly.  Ill check what you said about the plug wires, the PO has replaced the coil wires and plug caps though.  How hard is it to adjust Valves?  I have never done that before.
