If you remove the screw on the outside of the cover, it releases the clamp piece that holds the lifter mechanism to the cover. Then you can just push the entire lifter mechanism out of the cover. One it's out the two halves of the lifter will just unscrew from each other with about a 3/4 turn. While in there regreasing, check the seal that's on the collar for any tears and replace if needed.
