Author Topic: 1973 CB750 Custom Build on Hack A Week  (Read 145473 times)
Re: 1973 CB750 Custom Build on Hack A Week
« Reply #225 on: March 12, 2016, 05:19:19 PM »
I think most of us have a story like that Dino....at least the guys that have been riding for 30 years or so. ;D I was watching one of your videos the other day....when you were putting the cylinder head on. I was watching how careful you were not to drop the cam chain down the tunnel (you are very careful about all the stuff you do which is a great thing).  It made me remember building an engine for a fella and flipped the chain down the tunnel.....I thought he was going to have a heart attack. ;D ;D He was OMG...OMG....you have to pull the engine apart now.I remember I went an got an extendable magnet and brought it to the surface. I thought the dude was going to sh!t his pants. My point is the cam chain can easily be retrieved....I don't know where the the notion of the tunnel being a mechanical black hole came from but it isn't true. ;) ;D
Yup, I've seen that on other engine build videos, too. We all learn, little by little.   :D   :D :D
Offline mystic_1
  • 1970 CB750K
« Reply #226 on: March 12, 2016, 05:30:48 PM »
Dropping anything ELSE in there, though, does suck  :)
mystic_1
- John Augustus Shedd
« Reply #227 on: March 12, 2016, 05:35:37 PM »
mystic_1
That's right!  :D
Offline grepper
  • Busted Knuckles
« Reply #228 on: March 12, 2016, 06:44:11 PM »
You must have edited a lot out of that brake assembly, that took me forever to solve that puzzle.
Sent from my XT1254 using Tapatalk
Offline Dino
    • HackAWeek
« Reply #229 on: March 16, 2016, 04:57:20 PM »
OK guys I need some advice please. The P.O. provided most of the hardware to install a dual disc front brake setup. I have two discs, two complete calipers with mounting arms, new seals, the master cylinder with new reservoir. I'm missing the rubber hoses and hard lines and a way to split the single line from the master into two outlet lines to go to the calipers. Any suggestions on alternate parts for a dual disc setup? Thanks in advance.
If it ain't broke, don't fix it!
Offline wowbagger
  • Not much of an
« Reply #230 on: March 16, 2016, 05:03:09 PM »
You can split the lines by simply getting a double banjo bolt. That way you can keep the stock brake line union on the triple tree and just use a 2nd brake hose and hard line to connect to the other caliper.
The banjo threads are an M10x1.25.
Offline Dino
    • HackAWeek
« Reply #231 on: March 16, 2016, 05:20:43 PM »
Great idea and thanks! I just found this on Ebay for less than $20. Now I just need a longer banjo bolt and another hard line. :)
Offline wowbagger
  • Not much of an
Offline wowbagger
  • Not much of an
« Reply #233 on: March 16, 2016, 05:26:23 PM »
Though $13 gets you one with all the washers: http://www.ebay.com/itm/331780127095
Offline Dino
    • HackAWeek
« Reply #234 on: March 16, 2016, 05:28:41 PM »
Ha! Too late. Already bought the first one. I have washers at work. :) Thanks!
Offline Dino
    • HackAWeek
« Reply #235 on: March 16, 2016, 05:32:30 PM »
... and I just found another hose and line assembly for $22. DONE! I can always replace the hoses with new stuff later. I'm after getting it together and functional first, then doing some refinements later.
Thanks for the help!
Offline Dino
    • HackAWeek
« Reply #236 on: March 20, 2016, 12:22:49 PM »
« Reply #237 on: March 20, 2016, 12:35:52 PM »
You seriously rock, Dino!!  Well done.  Watch out for that tree branch on the way back into the driveway! ;)
Almost there!
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=f1ca0iuor3jebn1oetluu49nr1&/topic,60973.0.html
« Reply #238 on: March 20, 2016, 12:44:04 PM »
upper shock"s bolts....... ;) komes later...first test ride dont need all bolts in place..nice to see and hear it alive
« Last Edit: March 20, 2016, 12:45:36 PM by strynboen »
i hate all this v-w.... vords
Offline firebane
« Reply #239 on: March 20, 2016, 01:10:40 PM »
I'm not sure if I missed it or not but what size of tires are you running on that bike? I watched one video and they mentioned they were 18" rims.
« Reply #240 on: March 20, 2016, 03:03:07 PM »
CONGRATULATIONS!!
Offline knottedknickers
« Reply #241 on: March 20, 2016, 03:57:25 PM »
Sounds like you awoke the hounds! :) Love it! Enjoy the fruits of your labour.
CB750 K6 http://forums.sohc4.net/index.php?topic=141388.0
The plural of "anecdote" is not "data" (Borgmann 2002:5).
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #242 on: March 20, 2016, 04:06:39 PM »
HOORAY!!!!
Good call on the Oury grips. I have always been a fan of their mountain bike grips. I'll never get anything else for my CB750 now, either. Been running them since last year.
FWIW, if you don't have grip glue, ShoeGoo works wonderfully!
« Last Edit: March 20, 2016, 04:47:32 PM by evanphi »
--Evan
1975 CB750K "Rhonda"
Offline Bootsey
« Reply #243 on: March 20, 2016, 05:03:08 PM »
That's awesome work man, congrats!
Offline mystic_1
  • 1970 CB750K
« Reply #244 on: March 20, 2016, 06:59:41 PM »
Nice job Dino, bet you were smiling the whole ride.
mystic_1
Offline jamesw
« Reply #245 on: March 27, 2016, 09:50:31 AM »
Test drive!
Hey Dino! I've been watching Hackaweek for the past few days, and I wanted you to know how invaluable it is....you're a fantastic teacher, and have helped tremendously with my K5 build. It's fantastic to see your name here as a member. The amount of knowledge within this board is mind blowing. Your videos should be sticky'd....they alone answer a lot of questions that are commonly asked I bet.
Looking forward to watching next week's episode.  Keep up your great work.
72K-F 750 Cafe
75K 750 Cafe
75F 750 Restoration
Offline Inkswitch
« Reply #246 on: March 31, 2016, 06:17:49 PM »
Oh no, oh my god no. I'm so sorry to hear this. All that work... Made me sick to my stomach.  I've been following this build from the beginning and you have helped me during my build. Hoping for the best!
1971 CB750K1, 1987 Buick Grand National.
Offline mystic_1
  • 1970 CB750K
« Reply #247 on: March 31, 2016, 07:10:56 PM »
Offline evanphi
  • Apparently I'm an
« Reply #248 on: March 31, 2016, 07:17:13 PM »
FUUUUUUUUUUUUUUUUUUUUUCK
--Evan
Offline Bigsam302
    • 1976 CB750F (915cc) Super Sport
« Reply #249 on: March 31, 2016, 07:38:36 PM »
I just saw your latest video and I'm so sorry to hear that someone stole your bike. That is so f@#ked up and I hope that you catch the a#@holes that did it!  >:(  :( >:( >:( >:(
1976 CB750F (915cc) Super Sport: http://forums.sohc4.net/index.php?topic=142578.0
