SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
.25 .50 over rings
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: .25 .50 over rings (Read 912 times)
hymodyne
Expert
.25 .50 over rings
on:
September 12, 2006, 08:29:44 AM »
what exactly does .25 or .50 over mean in regards to piston rings? are they that fraction larger than standard rings for standard (not oversize) pistons?
hym
Logged
Tim.
Master
www.DOTHETON.com
Re: .25 .50 over rings
Reply #1 on:
September 12, 2006, 08:34:33 AM »
.25mm over standard bore, 0.5mm over etc. Pistons are made to match in .25 etc. over sizes. You wouldn't use .25 over rings on standard bore pistons I wouldn't think.
Logged
Roule comme dans les années 70... Roll as in the Seventies...
MotoRico
Full Member
Reply #2 on:
September 12, 2006, 08:36:12 AM »
Also called S1 and S2 respectively by some piston makers.
That was fun discovering when I bought some S12 cb500 pistons.
Logged
bryanj
Really Old Timer ...
CB500 Number 1000036
Reply #3 on:
September 13, 2006, 01:33:21 AM »
From Honda you get Std, 0.25, 0.50, 0.75, 1.00 and you use the same size rings as pistons fitting with any writing/numbers upwards!
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
.25 .50 over rings
