Author Topic: help with part numbers  (Read 1229 times)
750K4
« on: September 12, 2006, 10:55:44 AM »
I need to buy a set of the rubber grommets that hold the side covers on to my '69 750. I usually can use the parts fiche at crotchrockets.com, but the page that has these parts won't load. Anyone have another site that works, or, barring that, anyone know what the part numbers are for the oval (2 needed) and round (four needed) grommets? I also need the part numbers for the 3 special bolts and washers that hold the oil tank on (same fiche drawing). Help!
Offline JohnK6
  • I'm NOT Crazy, says the crazy man
Re: help with part numbers
« Reply #1 on: September 12, 2006, 11:20:00 AM »
sorry, i just red that it was for a 1969 CB 750, i thought i red CB 750K4 I'm sorry, so i modified my post with partnumbers for a K4 :)
« Last Edit: September 12, 2006, 11:23:21 AM by JohnK6 »
owner of: cb750k6(76), cb750k7(78), cb750K7(79)(sold), zwolle, netherlands
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: September 12, 2006, 01:49:12 PM »
The two you need are; 17247-303-000
The four you need are; 83551-300-000
This is from an old parts list reprint. If go through a dealer, here may be a superseded replacement, but they would be able to track/note that.
Hop on a Honda
« Reply #3 on: September 12, 2006, 03:08:55 PM »
Try this as the three Bolts to hold the Oil tank on.
#16 Bolt Part Number  90141-300-000
Good luck
(3of)
Dave Australia.
Offline old76cr
« Reply #4 on: September 12, 2006, 05:52:07 PM »
I have used this site to look up part #'s to order same from my dealer. They have exploded parts manuals you can browse of all US models            http://www.cmsnl.com/cb750-four-k0-us_model478/partslist/       Check it out. John. Timmins, Canada
cb750 k5        76 Husqvarna 250cr                                                       77 Can-Am 175   1973 honda SL125
750K4
« Reply #5 on: September 13, 2006, 09:42:03 AM »
old76cr
Thanks for the site info. It works great, and I have ordered the parts.
Hop on a Honda, Bob Wessner
Thanks, Gentlemen! I gave up trying to find these used and, with the numbers you guys provided, have placed an order with Service Honda.
