Author Topic: Ground wire?  (Read 409 times)
Offline Sdsbassist
  • Gus, Austin, MN.
Ground wire?
« on: March 29, 2014, 06:32:45 PM »
Is this supposed to be grounded to the frame somewhere?
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Ground wire?
« Reply #1 on: March 29, 2014, 06:41:52 PM »
Pretty sure mine is mounted under the head of the bolt that mounts the front coil bracket to the frame. If you look closely you can see it in the pict below:
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline riverfever
Re: Ground wire?
« Reply #2 on: March 29, 2014, 08:31:33 PM »
That's where mine is too.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Ground wire?
« Reply #3 on: March 30, 2014, 07:02:33 AM »
Perfect!
Sent from my PC36100 using Tapatalk 2
Gus, Austin, MN.
Re: Ground wire?
« Reply #4 on: March 30, 2014, 09:10:19 AM »
Disclaimer:
Ignore all the other wires (besides the ground) in the picture included in the previous post. I was in the process of cleaning up some PO's hideous hack job....  :o
It looks much better now.  8)
TAMTF...
Wilbur
Projects:
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Ground wire?
« Reply #5 on: March 30, 2014, 11:10:23 AM »
I actually had thought that in my head but didnt want to say anything :)
Gus, Austin, MN.
