Author Topic: Removing Old Brake Pad That is Stuck in Caliper  (Read 8191 times)
Offline ironandtime
    • Iron & Time
« on: March 31, 2014, 09:13:03 PM »
I thought I'd share what turned out to be a simple solution for removing an old brake pad that was stuck in the caliper. I simply drilled a hole in the middle of the face of the brake pad, then screwed in a small eye bolt (matching the hole size). Then all I had to do was to grip the eye bolt with channel lock pliers, and the pad came out right away.
1978 Honda CB550
Re: Removing Old Brake Pad That is Stuck in Caliper
« Reply #1 on: May 19, 2014, 05:00:34 AM »
How will you get the piston out?
Offline tomk1960
  • "We are the people are parents warned us about."
    • Tom's Cycle Recycling
« Reply #2 on: May 19, 2014, 05:27:35 AM »
Great suggestion on getting the pad out - thanks!
« Last Edit: May 19, 2014, 05:29:19 AM by tomk1960 »
2001 Kawasaki Vulcan 1500 Classic
1984 VF1000F Interceptor
1983 CB1100F Super Sport
1983 VF750F Interceptor
1982 CB900F Super Sport
1978 GL1000
1977 GL1000
1974 CB750 Four
www.tomscyclerecycling.com
Offline Honda550k
« Reply #3 on: May 19, 2014, 11:54:21 AM »
What I did was I hooked mine up to a mc and just pumped the piston and pad out.
« Reply #4 on: May 19, 2014, 12:02:02 PM »
Maybe pumping the piston out would get the pad out too?  ;D
« Reply #5 on: May 19, 2014, 05:44:07 PM »
That's what I was thinking.
Offline tomk1960
« Reply #6 on: May 19, 2014, 07:18:28 PM »
I'm going to be rebuilding the front brakes on my son's 550 and that's exactly what I did:
I used the C-clamp to keep the piston from coming out too fast or with force.
I pumped it out until it touched the clamp, then loosened it up a bit, pumped some more, etc.  I had it all apart in a few minutes.  What a mess it was inside!  The brakes will be like new when I'm through with them.
1978 GL1000
1977 GL1000
1974 CB750 Four
Offline ironandtime
    • Iron & Time
« Reply #7 on: May 19, 2014, 09:08:44 PM »
Hey guys - I should have clarified...that there piston and brake pad were totally seized up and rusted all to hell on the inside. Pumping the brake to get the piston to push it out was a no go, so I had to take it to the next step!
1978 Honda CB550
« Reply #8 on: May 19, 2014, 09:13:37 PM »
Offline krusty
« Reply #9 on: May 19, 2014, 10:23:03 PM »
Sometimes you need more pressure than the MC can give. This is where the grease gun method shines, and less mess. See this thread;
http://forums.sohc4.net/index.php?topic=101649.msg1551835#msg1551835
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
« Reply #10 on: May 20, 2014, 02:57:16 AM »
As long as you don't drill the housing to push the piston out  ;D
Somebody had a picture here what the PO did to a brake caliper.  Drilled a hole, pushed the piston out and plugged the hole again.
For stuck piston off the bike or when the MC is not strong enough there is either grease gun or compressed air.  Compressed air - from what I understand, I always use grease gun - is more fun, since the piston shoots out very fast, but grease gun is the preferred method.
Offline vfourfreak
  • Do you think that's wise
« Reply #11 on: May 20, 2014, 04:34:08 AM »
I had a Yamaha TZ caliper split last year. The piston on one side came out fine, other side, not a chance. For  several reasons I could not set up the grease method, so I went for compressed air. I stood behind it, and set up a cardboard box  well padded to receive the piston. Applied the air in many short bursts, I could see the piston straining against the seal. Bit by bit it moved, then POP out she came and almost went through the end of the box which was padded with a large jiffy bag. Certainly a method to be done with caution.
Kev
Offline Oz350Four
  • Keep yer stick on the ice...!!!
« Reply #12 on: April 23, 2015, 03:43:09 AM »
 ??? I've just finished removing all the parts from my cb350f front end including brakes etc.
The bake pad is stuck in the calliper still. I've read the posts about grease gun yada yada yada...
The MC is still connected to the lines as is the calliper, however the brake fluid has been removed.
As I don't have any brake fluid at my disposal would it be Ok to fill the line and MC reservoir with water to push it out and then draining it again..??  I wont be putting it back onto the bike for some time and will it probably be dry by time I go to reinstall.
"Me speed officer...?? never..!!!"
1972 CB350F Four - Project Ol' Red (current)
2007 Harley Davidson Softail Deuce - Sold to start this project.
Offline calj737
  • I refuse...
« Reply #13 on: April 23, 2015, 03:53:28 AM »
I wouldn't, due to the presence of water in your system being a long term problem. Moisture causes corrosion and all that yada yada yada nonsense.
You have two simple solutions: DOT 3/4 or the old grease gun method. Which do you prefer? If it were me, I'd use DOT 3 as it will-
1-allow me to purge the old lines of all the old crap built up over 40 years
2- allow me to extract a stuck piston without further clean up necessary (grease gun works, but is a tad messy)
3- provide me with enough fluid to refill my system after a proper rebuild of the caliper and bleed of the system.
DOT 3/4 is available nearly anywhere and is the simplest solution to solve your issues. Yada yada yada and all that....
« Reply #14 on: April 23, 2015, 05:30:17 AM »
Water...you kidding?   Yadayada, listen to Cal, yadayada
Offline koendd
« Reply #15 on: April 23, 2015, 06:44:07 AM »
my thoughts exactly! doesn't cost much!
Yad... (nevermind... :) )
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline LesterPiglet
  • 1977 CB550F2
« Reply #16 on: April 23, 2015, 10:13:13 AM »
Throw some thin oil in, it won't hurt it.
Offline Oz350Four
« Reply #17 on: April 23, 2015, 04:04:09 PM »
Thanks folks I'll wait till I can get the Dot 3 fluid as you've suggested.
And also thanks for enlightening me about the intricacies of water in a brake system / line... I wasn't sure that's why I asked the forum...
I'll make sure the yada word doesn't get mentioned again by me... After that lot I'll have trouble even with yoda..!!!
Offline el__burro
« Reply #18 on: June 26, 2015, 05:17:35 PM »
Did a few times with a grease gun,  cheap and effective.
El__burro
