Author Topic: Dammit! It's not a sandcast! But...  (Read 13786 times)
Re: Dammit! It's not a sandcast! But...
« Reply #50 on: April 06, 2014, 05:18:07 AM »
Looks like it was already broken at some point and somebody did the JB Weld if it was like that when you got it.
Offline Tews19
  • I am no
« Reply #51 on: April 06, 2014, 03:49:14 PM »
Great find. With the sprocket cover removed I noticed a guard....... I have never seen one of those before. You may want to go the Vermont route if the title does not come up.
1970 Honda CB750 survivor.
Offline slyguy
« Reply #52 on: April 06, 2014, 05:19:18 PM »
No that was my try:( I also unfortunately blew apart the stock ruby red air cleaner:( I really slowed down from that point forward, lol.I just disassembled everything and cleaned up the cases & carb bodies then put it all in bins for now. I'll probably start back into it soon though.
Offline Prospect
« Reply #53 on: April 06, 2014, 07:20:23 PM »
Hard to tell but is that a recessed ignition switch?
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #54 on: April 06, 2014, 07:54:10 PM »
Definitely...I see a black plug.
Offline goldarrow
  • one day, i'll be an
« Reply #55 on: April 06, 2014, 08:22:41 PM »
Yes, recessed key ignition, with two extra keys unrelated to the bike
CB550 K0
Offline goldarrow
« Reply #56 on: April 06, 2014, 08:24:38 PM »
In CA, getting bikes that has been out if system isn't all that trouble, just need to take the bike in for inspection, but yes will consider Vermont route as an option
CB550 K0
Offline Greggo
  • Somebody's
« Reply #57 on: April 06, 2014, 09:11:49 PM »
« Reply #58 on: April 06, 2014, 09:18:01 PM »
Gold - you should consider putting a proper paint job on that bike. Would be worth the investment in the end.
Offline Greggo
  • Somebody's
« Reply #59 on: April 06, 2014, 09:20:50 PM »
What numbers on them?  I may be interested in one if it's right, and you want to sell..
Offline goldarrow
« Reply #60 on: April 06, 2014, 09:25:28 PM »
Should have mention those extra keys are regular keys, I also have few other honda keys that I don't have ignition for.  Pm me if you have specific numbers that you need, or I'll look and make list.
CB550 K0
« Reply #61 on: April 06, 2014, 09:27:31 PM »
Check to see if the sunken key fits seat and steering lock.
Offline goldarrow
« Reply #62 on: April 06, 2014, 09:29:56 PM »
Yes, have already been considering options.  Candy blue/green was its original, so I'll stick with that.  Yamiya set seems to be the easiest route, other option is source parts and paint kit from don dirty biker and paint myself but of course I make mess more than make good, lol
CB550 K0
Offline goldarrow
« Reply #63 on: April 06, 2014, 09:31:07 PM »
Yes it did and work flawlessly, checked that the other day :)
CB550 K0
Offline Greggo
  • Somebody's
« Reply #64 on: April 06, 2014, 09:36:35 PM »
Dag!  Was hoping they were plug keys...I want a spare for my sandy, but don't want to spend $50 ;D
Offline Greggo
  • Somebody's
« Reply #65 on: April 06, 2014, 09:37:52 PM »
You mentioned the wrinkle tank is chromed, right?  I wonder if it can be saved/re-painted?
Offline goldarrow
« Reply #66 on: April 06, 2014, 09:45:17 PM »
Haven't really paid attention to the tank, but parts of it looks chrome, some surface rust, may be it was painted chrome??? But I think it could be saved.
I just can't touch this bike too much right now unless I sell a bike, you know...funding issues
CB550 K0
« Reply #67 on: April 07, 2014, 06:42:29 AM »
Greggo - I have a couple: T9927 & T7927.....
« Reply #68 on: April 07, 2014, 07:31:37 AM »
My buddy who sold the $25,000 Sandcast needed keys for his recessed ignition for that bike because the original was lost and simply walked into our local long established Honda dealer and picked up two they had in stock cheap. They did not have the plastic on them like original but worked perfectly.
Offline slyguy
« Reply #69 on: April 07, 2014, 08:05:50 AM »
how again, do you end up with some sort of a replacement title? wait a minute..mines a 70. titles werent around then? though I do need a reggy to license here in ny..not that I'm ready but good idea before sinking alot of cash into it?
Offline goldarrow
« Reply #70 on: April 10, 2014, 07:53:15 PM »
I'm having it real easy with this bike so far. Got the master cylinder cleaned reusing old kits, flushed the line with new fluid, front brake is good to stop. Few drops of marvel mystery oil into the clutch cable, broke it free. Put in later style air box, and just need new filter.
CB550 K0
« Reply #71 on: April 10, 2014, 08:07:02 PM »
You clean the carbies yet, Gold?
Offline goldarrow
« Reply #72 on: April 10, 2014, 08:10:09 PM »
Yup. Done deal. Had a bit of hard time removing the float pin on #1, but I won at the end :)
CB550 K0
Offline goldarrow
« Reply #73 on: May 14, 2014, 11:41:54 AM »
We'll dammit.  I messed up float bowls on #3 and 4, those drain screws just won't budge, broke off, and cracked one bowl try to left hand drill it out.
But Stev-o is coming to the rescue with later type bowls, should work for now.   Also center stand is coming in, and 16 incher is coming off the bike soon.  I have a 18" DID rear wheel from my k6 to replace, but should I go through the trouble and swap the wheel hubs?
CB550 K0
Offline Greggo
  • Somebody's
« Reply #74 on: May 14, 2014, 12:08:11 PM »
I would not do all that for a K6 rim.  Just save the two hole hub in case you find a nice K0 DID rim without all the stampings, or by some miracle find a decent rolled rim.  That's my two cents.
