Author Topic: Rotor/Rear Sprocket Lock Nuts  (Read 1511 times)
Offline stwinton
« on: April 05, 2014, 05:55:15 pm »
Is there any alternative to using the old school bent washer trick to lock the rotor nuts and rear sprocket nuts? The nuts are thinner than usual so I suspect that nylon lock nuts won't fit. Or is there another reason why we have to stick with original spec?
Thanks!
PS...the CB550 is in its component parts...I await deliver of the long nosed C ring pliers from Dime City Motorcycles. 3 weeks to Australia! Might have to re-think this vendor...
We will either find a way, or make one
Offline raymond10078
  • Just learnin' as I go . . . .
Re: Rotor/Rear Sprocket Lock Nuts
« Reply #1 on: April 05, 2014, 06:16:57 pm »
Later bikes used flange nuts - with no locking mechanism - that's what I went with on my 750.
My son's 450 has similar nuts.
I didn't catch the year of your bike, but I'd bet you have 10mm studs.  If so, this should work:  90308-382-670 or 94050-10080.
« Last Edit: April 05, 2014, 06:19:50 pm by kandrtech »
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline stwinton
« Reply #2 on: April 05, 2014, 10:06:07 pm »
hi kandrtech
Thanks for the heads up about flange nuts. I have seen them but didn't know their name.
My little beast is a 1974 frame 75 engine. Its in pieces right now...down to its component parts.
The last bike I did (Bultaco 1971 Sherpa T) I replaced every nut, both and washer with new. Including nylon lock nuts AND star washers. But I never used a single flange nut...another bit of knowledge. Thanks!
Offline TonUp_UK
« Reply #3 on: April 11, 2014, 02:01:22 am »
I have a CB550F2 1977. Just doing a bit of restoration and I have ordered a set of M10 flange nuts to replace the original nuts / ali plate setup.
Problem is - the new M10 flange nuts will not fit, looks like there is a special thread on the studs? I have measured the studs and they are 10mm?
Any ideas?
« Reply #4 on: April 11, 2014, 03:31:33 am »
I suspect that they are fine threads...not "special".  I see three nuts sizes/threads: M10-1.0, M10-1.25, and M10-1.50.  The 1.0 is a fine thread, and the 1.50 is a course thread.
« Last Edit: April 11, 2014, 04:13:21 am by kandrtech »
Offline TonUp_UK
« Reply #5 on: April 11, 2014, 04:18:48 am »
So, M10 x 1.25 or M10 x 1 . Which is the correct one for my CB550?
« Last Edit: April 11, 2014, 04:20:48 am by TonUp_UK »
« Reply #6 on: April 11, 2014, 08:10:31 am »
Best way is to measure.
Count ten threads and measure in mm, then divide by ten.
« Reply #7 on: April 11, 2014, 08:14:53 am »
Get a pitch guage or measure, most bolt sizes have several pitches.
Offline Airborne 82nd
« Reply #8 on: April 11, 2014, 09:02:07 am »
Offline TonUp_UK
« Reply #9 on: April 14, 2014, 03:18:04 am »
I bought these off ebay "M10 x 1.25 Smooth Faced Locking Flange Nuts" and they are spot on.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #10 on: April 14, 2014, 03:45:55 pm »
M10x1.25 is Honda standard
« Reply #11 on: April 14, 2014, 04:16:42 pm »
Standard for what, exactly?  750 rear sprocket nuts are M12.  I forget what I ended up getting - possibly M12x1.25.
Offline calj737
  • I refuse...
« Reply #12 on: April 14, 2014, 05:50:12 pm »
1.25 thread pitch for M10 bolts and nuts, plus caliper blind holes, etc...
« Reply #13 on: April 14, 2014, 05:56:26 pm »
Thanks.  Good to know.
