Author Topic: 1975 CB750 K5 "Rhonda the Honda"  (Read 94016 times)
Re: 1975 CB750 K5 "Rhonda the Honda"
« Reply #125 on: June 29, 2015, 03:17:18 PM »
Other than a ticking sound, that lone broken spoke could have been there for some time without anyone noticing. That said, a new one will fix her up.
That's what I figure. I know I did hit a pretty nasty pothole a few weeks ago. Rim not bent or anything, but might have popped this spoke.
OR it could could have always been there and I just didn't notice!
EDIT:
Hmmm... looking at this photo from a month or so ago, I think this broken spoke is new! Possibly that pothole I hit... All the spokes are intact in this pic.
That sounds likely.  The stress of the pothole was displaced but the spoke could not stretch enough.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #126 on: July 06, 2015, 06:48:31 AM »
Installed my front wheel bearings. Pretty straightforward process... But that axle bolt is a BASTARD! Could't find a deep enough socket to turn it off, because of the lip at the end, so I went with two wrenches. The axle nut is 23mm... an odd size. 7/8" is the equivalent SAE size! The two flat areas on the other end of the axle is 18mm. I let it soak in PB Blaster for awhile, then heated it up for about 30 secs and pressed down on both wrenches at the same time. POP. Off it came.
Removed the disk brake, etc so that the speedo drive hub could come out.
Drilled out the original stakes with a 1/8" bit, and tapped out the retainer ring. Buggered the slots a bit, but it works still.
Plenty of rust in there!
Following przjohn's method (http://forums.sohc4.net/index.php/topic,149230.msg1702391.html#msg1702391), I popped out my bearings. Didn't need to heat the hub, either. Just a nice big punch, and a screwdriver jammed in there, a few taps with the 5lb mallet, and POPPED right out.
The bearings. Originals! Notice a few pics back... no previously-drilled out stakes on the retaining ring!
From here it was a pretty simple process... Retainer-side first, using the old bearing to get it in place. Don't hammer the inner races!
Then put your retaining ring back on. But first you'll want to clean up those threads. They are pretty soft metal, so easily done! The thread pitch for the retaining ring on the front wheel is 1.5mm, the same as an M10 bolt. Luckily that is the same as the oil drain plug. I just changed mine so I had the old one kicking around. Run that bolt with plenty of pressure around the retaining ring, and also on the hub inner threads. Any spots that are especially warped, like on mine where I used a punch to turn it out, and where the original stakes were drilled out, use a small jeweler's file to get rid of the big chunks, then the M10 to reshape.
So pop that retainer back on, and get the original stakes to line up. Make sure to punch new ones when you're finished!
Spacer... Make sure the NARROW END goes on the RETAINER SIDE. This photo shows the WIDE END.
Use the old bearing to get the new bearing to seat flush, to start.
NOW AN IMPORTANT PART.
Don't drive that bearing too tight! You want the inner spacer to be able to move, ever so slightly, but not too loose either!
The little sliver of silver you see in the center here is the opposite side's inner bearing race.
This means that the spacer moves, still (it was loose at this point). Notice in the pic above of the spacer that it isn't a super tight fit in the hub. It can move vertically (wheel upright as if on bike). You don't want it moving side to side, though, as that is too loose. It is all by feel...
How I found the magical "Just RightTM" position for this floating bearing is that it should be tight enough so that the spacer doesn't move side to side (remember wheel in normal, riding position... up or down is OK), BUT you should be able to spin both bearings freely, in opposite directions, at the same time, independently of the spacer. You may find you can feel the inner race rub ever so slightly on the spacer at this point. It takes a bit of feeling around (use your pinky's, those are small holes!)... but you'll get it.
If you do make it too tight the first time around, GENTLY tap from the retainer side on the INNER RACES. GENTLY GOING SLOWLY, ALL THE WAY AROUND. Eventually you will get the floating bearing moved outwards a bit, and then you can try again. Ask me how I know... I thought I was done for, when I did it too tight... but I went and checked HondaMan's book, and this is what was recommended.
Then reassemble everything! Change the seals if they were included, and grease where necessary. Disk brake bolts are M8, so they were tightened to 15#, in a cross pattern, and then the lock washers bent up again. I should get new ones. Front axle is supposed to get fairly high torque, but finding a socket that actually fits is going to be near impossible. I used those two wrenches again and tightened to gudentight (all my 170lbs pushing on them). Fork axle holder is installed with the gap to the rear, front bolt tightened first (15#, again), and then the rear to the same torque.
I rode the bike this morning, and I found that the bike rolled much better when backing out of the garage.
Rear wheel bearings, cush drive rubbers, and spockets and chain are for next time!
« Last Edit: July 06, 2015, 07:08:44 AM by evanphi »
--Evan
1975 CB750K "Rhonda"
« Reply #127 on: July 07, 2015, 06:25:22 AM »
Good job!
Offline evanphi
  • Apparently I'm an
« Reply #128 on: August 17, 2015, 06:50:18 AM »
Made a small bracket to relocate my Acewell speedo from the left triple tree mount to the center. I also bent it in the middle so it sits flat. Now I can actually see what speed I'm going!
--Evan
Offline calj737
  • I refuse...
« Reply #129 on: August 17, 2015, 03:12:31 PM »
Jeepers! If the crack in that cement gets worse you'll lose your bike into it  :o a sinkhole like that ate some priceless Corvettes not to long ago  :-\
Offline evanphi
  • Apparently I'm an
« Reply #130 on: August 18, 2015, 05:04:20 AM »
HA!
That is one of the next house projects on the list... after windows and siding. I just hung a new garage door last week... and I need to put a new pad down on top of this cracked one.
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #131 on: September 08, 2015, 06:34:42 AM »
Replaced the stacks in the airbox, big difference in diameter and length.
I have a funny feeling the throats on mine are too long... my airbox tilts backwards. Or maybe my intake boots are too long.
Anyone have a comparison shot of aftermarket vs. original intake rubbers?
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #132 on: September 15, 2015, 10:48:24 AM »
Found a PO wiring kerfuffle...
The main ground wire for the headlight bucket came loose. The Acewell gauge started flickering while I was riding, and then went completely dead... but I was still riding. Engine still running. HMMM. Then when I tried shutting off the bike and fiddling, it wouldn't come back on. Figured some sort of loose wire... boyyyyyy was I right...
EMergency roadside repair... stripped the wire back and taped/ziptied the bare wire end to the ring terminal. Worked well! Going to do some major rewiring work this weekend.
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #133 on: September 15, 2015, 10:49:08 AM »
--Evan
« Reply #134 on: September 15, 2015, 11:44:14 AM »
Bummer about the wiring.  Good on you fixing it on the roadside.
« Reply #135 on: September 16, 2015, 09:28:38 PM »
What are those extra ground wires for?
Offline evanphi
  • Apparently I'm an
« Reply #136 on: September 17, 2015, 07:45:35 AM »
Going to find out...
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #137 on: September 19, 2015, 08:49:30 AM »
Un-screwed some PO wiring...
Here we see the wiring from the PO, with the main ground wire to the front half of the bike broken off. See previous post. Repair is below it.
PO had the frame powder coated before their rebuild. How nice. Too bad they didn't do any proper wiring... So I sanded back the PC and ran this wire up to where the others were attached. Also applied some dielectric grease to protect the bare metal.
Couple snips here... a few crimps there...
The three on the right are for the tail lights, regulator, and rectifier.
Applied a little heat for some shrinkage... (very high quality automotive heat shrink with glue)
TA DA! Factory-correct harness ground! Hooray!
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #138 on: October 26, 2015, 06:12:33 AM »
Picked up some Shell Rotella T 15W40 yesterday.  5L for 28$. Still a few weeks left of riding, then going to change the oil and lay up for the winter... then the front end work can begin!
--Evan
« Reply #139 on: October 26, 2015, 06:17:03 AM »
I would get depressed if I had to lay up for winter.
What is the plan for the front end?
« Reply #140 on: October 26, 2015, 06:49:47 AM »
Same here, about 40F is my limit - in VA thats only few days in winter.
Offline evanphi
  • Apparently I'm an
« Reply #141 on: October 26, 2015, 07:15:41 AM »
Changing to tapered head bearings, for one (already purchased). And replace the bars. Bent the left side last year when I dropped it and had to repair the stator cover.
My fork tubes are also bent slightly, so I'm going to try straightening them... but I'll likely end up buying the kit from CycleX, new tubes, progressive springs, and seals. 200US is a good deal.
http://www.cyclexchange.net/fork_tubes_and_accessories.htm
Then also going to center the front rim to the hub. It is almost a full centimeter off to the RIGHT. The opposite direction from Honda... The PO had everything as a box of parts and installed the disk on the wrong side.
Plan to also go through all the electrical and clean up all contacts. Reorganize under the left side cover.
And finally going to do a clear tube check on carbs.
« Last Edit: October 26, 2015, 07:28:15 AM by evanphi »
--Evan
« Reply #142 on: October 26, 2015, 07:47:16 AM »
I did a similar front end upgrade to my K4 last winter:  tapered bearings, Progressive springs, polished fork lowers, new wheel bearings, fork seals and dust boots [one thing leads to another!]
Would be a good time to powder coat the triple too.
Offline evanphi
  • Apparently I'm an
« Reply #143 on: October 26, 2015, 07:53:04 AM »
Yes it would... there is some chipping paint. I kind of want to polish it for something different. Probably go PC though... Already have wheel bearings, and I have the mini dust boots.
--Evan
« Reply #144 on: October 26, 2015, 07:54:38 AM »
Actually, I polished the aluminum Triple top, but painted the lower as it is steel.
Offline evanphi
  • Apparently I'm an
« Reply #145 on: October 26, 2015, 08:03:57 AM »
I'm also going to a single brake line, so removing the stop switch. This is where it needs the paint, really... Maybe a paint and bake is in order! I like the look of a polished upper.
--Evan
« Reply #146 on: October 26, 2015, 08:11:25 AM »
Yes, I like the polished triple top look too.
Mine...
Offline evanphi
  • Apparently I'm an
« Reply #147 on: October 26, 2015, 10:58:27 AM »
Well that made my decision easier. hahah. I have the two individual bar clamps rather than the dash, so they should polish up nicely too.
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #148 on: December 08, 2015, 07:40:09 AM »
I built up Rhonda's bed for the winter. 8'x2.5' 2x4 frame with 3/4" ply over top. Lag eye screws in the corners so I can tie down the rear end to lift the front for the work this winter (frame will have some blocking to make sure nothing goes awry). Will buy a front wheel chock at some point if I ever need to... for another bike maybe. Should also add some casters so I can move it... but no point now with that HUGE crack in my slab. :P
Also covered my boat for the winter.
« Last Edit: March 09, 2016, 07:24:56 AM by evanphi »
--Evan
« Reply #149 on: December 08, 2015, 07:38:07 PM »
