Author Topic: 1975 CB750 K5 "Rhonda the Honda"  (Read 90489 times)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: 1975 CB750 K5 "Rhonda the Honda"
« Reply #175 on: March 01, 2016, 06:02:35 am »
Front wheel is all trued up... less than 1mm deviation axially and radially. That was fun! Lots of oil on the nipples.  ::)
Now just waiting on my brake line from Slingshot, plus another package from a forum member. Rhonda's getting a set of play clothes (as my daughter would call them).
--Evan
1975 CB750K "Rhonda"
« Reply #176 on: March 01, 2016, 10:35:52 am »
Mind in the gutter!   :o ;D
Offline evanphi
  • Apparently I'm an
« Reply #177 on: March 05, 2016, 02:44:42 pm »
Took apart my clutch side switch to polish and grease the contacts for the horn and beam select switches. Nice and shiny now.
Front wheel is all trued up and centered, and disk is back on. All that's left now is to torque up the bolts and put back on the bike along with the handlebar. Rhonda will ride again soon! Next weekend I pick up my brake line...
--Evan
« Reply #178 on: March 05, 2016, 03:01:11 pm »
That polished lever is pretty shiny for someone...
... not really one for lots of shine.
Offline evanphi
  • Apparently I'm an
« Reply #179 on: March 05, 2016, 07:46:15 pm »
Front wheel back together... torqued axle bolt to 45#. (this photo was before I did final torque on the disk nuts, that's why the tongues aren't bent over yet)
Wheel and bars installed
Bucket on, wires routed (Rhonda's puking after a long winter bender)
Assembled!
Now I just need that brake line, which I am picking up next Saturday.
« Last Edit: March 06, 2016, 06:17:58 pm by evanphi »
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #180 on: March 14, 2016, 08:12:23 am »
Everything is all buttoned up... had to replace the headlight fuse, but everything works and the AGM battery was still above 12V, being stored indoors all winter. Great battery!
BUT THEN...
FUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUCK.
It's all still holding, but this one holder for the new headlight ears CRACKED. I've contacted the seller for replacements...  >:(
Just need some fresh gas, and I'll do a clear tube check before riding.
--Evan
« Reply #181 on: March 14, 2016, 08:16:36 am »
That was a good catch.  I had a headlight bucket break (with a HEFTY die-cast Truck-lite housing) while I was riding once.  It was no fun having to cradle my headlight for 40 miles.
Offline evanphi
  • Apparently I'm an
« Reply #182 on: March 21, 2016, 05:38:38 pm »
Looks like the sidecovers I got from edwardmorris were originally orange flake. neat!
Going to work on getting as much paint as possible off these, and then picking out what colour do to them with. Not going to be too fussy with leftovers, though... going to be rattle-canned.
« Last Edit: March 21, 2016, 05:40:55 pm by evanphi »
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #183 on: March 31, 2016, 09:23:52 am »
Is it safe to use a wire cup brush or wheel brush in a mini-grinder on these tanks to remove all the old paint (and prev PO horrible paint job)?
Or should I use chemical strippers?
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #184 on: April 02, 2016, 09:12:19 am »
Rhonda rides again!
Went for a quick shakedown ride today after setting float heights. Glad to be back on the road with her.
The bottom of the meniscus sits right at 3mm for all the carbs. I measured them all off the same carb so they're as equal as they're ever gonna get! They all had to come up about 2mm.
Pro tip: If you want to raise the float height without removing the float (and losing your needle) each time, you can reach in there and give the tang a pinch (to lower it) with some long-nose needle pliers. If you need to lower your fuel level, raise the tang up with a flat screwdriver. The hose for mine is made with an old drain plug that I cut the head off, and jammed onto a piece of 1/8" fuel line.
« Last Edit: April 02, 2016, 09:14:03 am by evanphi »
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #185 on: April 17, 2016, 09:56:16 am »
Rhonda's Glam shot, 2016.
--Evan
« Reply #186 on: April 17, 2016, 10:31:57 am »
Very nice.  It still looks a wee bit chilly from the look of the hibernating grass and trees.
Offline evanphi
  • Apparently I'm an
« Reply #187 on: April 17, 2016, 10:59:43 am »
+8 Celsius in the direct sun. Cool, but you'd still get a sunburn.
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #188 on: April 17, 2016, 11:05:00 am »
This wash made me realize that VHT Header paint really sucks.
Going to wrap those crappy MAC headers soon, then look into getting a stainless set made/purchased. Maybe Hindle.
Also need to touch up the black engine paint.
--Evan
« Reply #189 on: April 17, 2016, 11:46:33 am »
It most likely comes down to prep. Did you sandblast before paint?
Offline evanphi
  • Apparently I'm an
« Reply #190 on: April 17, 2016, 02:01:09 pm »
I didn't sand blast but I had removed everything with chem stripper. Also notice the grey primer is holding fine...
--Evan
« Reply #191 on: April 17, 2016, 06:06:08 pm »
I haven't heard the Hindle on a 750 but it sounds great on the 550 and 650.
Offline evanphi
  • Apparently I'm an
« Reply #192 on: April 20, 2016, 05:14:29 pm »
Gave Rhonda's jugs (hehe) a clean, and spot-sprayed some flat black engine enamel. Next will be touchups on the pipes.
--Evan
« Reply #193 on: April 20, 2016, 10:26:57 pm »
So, you spruced up her jugs, and didn't even have to see a plastic surgeon in Newport Beach.
Offline evanphi
  • Apparently I'm an
« Reply #194 on: April 26, 2016, 09:32:41 am »
I set up my progressive springs with the recommended amount of fork oil from the factory manual (rebuilding from dry), as well as the 1" PVC spacers. My forks are now topping out (hearing a ka-thunk after going over a longer bump with some speed). Is it just too much preload for my weight (170lbs)? I just find the ride is overall more harsh than before.
Should I just try running without the spacers to reduce preload?
--Evan
Offline edwardmorris
  • Youngish
« Reply #195 on: April 26, 2016, 09:38:43 am »
What weight oil? I'm 175lb (after a good buffet lunch :P), using factory spec amount (rebuilding from dry) and no spacers with 10w30 diesel engine oil, the front is damn near perfect.
Offline evanphi
  • Apparently I'm an
« Reply #196 on: April 26, 2016, 10:40:06 am »
10W fork oil, 225mL per leg.
Are you running progressive springs, Rafi?
--Evan
  • Youngish
« Reply #197 on: April 26, 2016, 12:10:37 pm »
Yep, on both of mine.
« Reply #198 on: April 26, 2016, 02:44:05 pm »
I did not use the spacers on my K4 and all is good.  And used ATF.
Offline evanphi
  • Apparently I'm an
« Reply #199 on: April 26, 2016, 02:44:10 pm »
I think I'll take my spacers out, then. See if that makes a difference. They just feel super stiff now, front end feels harsh. That to me says too much preload.
--Evan
