OK so shop night was tonight.
First thing's first, put the LED lights into the tach. They don't seem a whole lot brighter. Oh well.
Next up, cut and routed the new 3.5mm drain hoses for the carbs. Hopefully they stay nice and rubbery for a long time. They all sit about 1.5" below the center stand axle.
That was all I needed to do tonight. But I also wanted to see why that tail light was flickering last week.
Took it off and disassembled it, then remounted. Nothing out of the ordinary.
Then I removed the rear brake switch and routed the wiring through the hole in the rear engine mount just ahead of the oil tank drain bolt. Seems like a smart place to run it. When I turned on the bike the rear brake switch was activated, so I had do dial it down. I think this may have been why it was blinking previously.
Started the bike up again to hear it roar. No more blinking brake light. Could have been the switch, or could have been the mounting screws for the light, which is how it grounds, being dirty. On second thought it was the switch. The lights were all turned off when I did that video. The switch was just too tight and was vibrating on.
Not wanting to waste any more time, I mounted the Delkevic muffler bracket/stand stopper to the right passenger peg bolt. Had to open up the hole slightly to fit the M12 bolt that holds the peg on. Will have to further elongate this hole so the bracket sits a bit lower. The center stand foot on the left side of the bike seems awfully close to the chain.
Last up to fabricate is an exhaust reducer pipe for the collector to the muffler. The reducer pipe needs to be 16GA stainless steel reducing from 2.5"ID to 2.25"OD. Looks like best option is going to a muffler shop for this. 2.25" OD stainless 16GA exhaust pipe, and then have the end expanded with a hydraulic expander to 2.5" ID.
The steering damper bracket/speedometer bracket should arrive Wednesday, and I also ordered the Magna 5OHM coil and wire set from 4into1. That should arrive soon too.
Seeing more and more bikes out on the road as our mega snowfall keeps melting...
