Author Topic: Sonic cleaning of carbs  (Read 1151 times)
Offline Toxic
« on: April 07, 2014, 05:58:06 AM »
Hi Guys
Just bought a sonic cleaner to clean carbs and other assorted parts and after doing a search it seems there are a few on here using them with success.  What are you guys using as a cleaning agent in the water.
I saw one post where Pine Sol was used anything else that does a good job?
Gary
Offline calj737
  • I refuse...
Re: Sonic cleaning of carbs
« Reply #1 on: April 07, 2014, 06:06:59 AM »
My best experience came with a diluted mixture of Simple Green (the aluminum safe formula) and water.
« Reply #2 on: April 07, 2014, 06:32:20 AM »
It doesn't matter much. It's the cavitation that does it. The old stuff your grandma washed dishes with will do perfectly. BTW, why are you all so keen on ultrasonic cleaning? Aren't the jets the smallest passages? You can take them out and clean them manually.
« Last Edit: April 07, 2014, 06:36:40 AM by Deltarider »
Offline Toxic
« Reply #3 on: April 07, 2014, 06:37:10 AM »
Ah ...  I thought there was a secret recipe.  thanks
« Reply #4 on: April 07, 2014, 11:26:55 AM »
pine sol is acidic and will slowly dissolve carbs
use simple green.
"This is my CB. There are many like it, but this one is mineā€¦"
Offline fire113
« Reply #5 on: April 07, 2014, 01:06:27 PM »
...You can get special carb cleaning stuff for ultrasonic. I am very happy with it  ;)
« Last Edit: April 07, 2014, 01:08:05 PM by fire113 »
Offline Bru-tom
« Reply #6 on: April 07, 2014, 01:10:13 PM »
also keen to find a solution for cleaning ally carb bodies..
Offline 750K
« Reply #7 on: April 07, 2014, 10:26:18 PM »
Why don't you share the name of this magical stuff, lol. After all that's what the OP wanted to know...
77 Cb750, 78 Kz1000
Offline brewsky
« Reply #8 on: April 08, 2014, 03:19:04 AM »
This is why I would like to have one handy..... :( :( :(
« Last Edit: April 08, 2014, 03:21:08 AM by brewsky »
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
« Reply #9 on: April 08, 2014, 03:54:50 AM »
I've read various experiences.
cf. http://www.sohc.co.uk/index.php?topic=6443.0 (scroll down)
Offline Toxic
« Reply #10 on: April 08, 2014, 04:09:23 AM »
use simple green.
Thanks for the info... I didn't know that.   Don't want to be creating more problems for myself
Offline Toxic
« Reply #11 on: April 08, 2014, 04:10:21 AM »
Those are pretty dramatic results so what did you use?
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #12 on: April 08, 2014, 04:57:01 AM »
i am looking at both units from harbor freight, the lil one for 40 and the big one for 80.  i know some of us have bought from harbor, who has which unit, and will it hold all 4 carb bodies, or just one at a time?   how long does a cleaning cycle typically take?
MATT
Offline 750K
« Reply #13 on: April 08, 2014, 09:36:18 AM »
You're not entirely correct, they work hand in hand. You get better faster results with a good quality cleaning solution than with a #$%* one. People are keen on it due to it working great when you have it running properly, I always find people slag on it when they half assedly use an ultra sonic or buy a $40 on and expect it to perform miracles. Not all ultrasonic cleaners are created equally, you get what you pay for and if you want a strong one expect to pay more than $100. I've been using them at work for almost 14years, there's $40 one and there's $1400 units. All have an intended use.
77 Cb750, 78 Kz1000
« Reply #14 on: April 08, 2014, 10:13:43 AM »
I repeat: it is the cavitation that does the trick. Whatever you use as a detergent is simply to embody the dirtparticles so they won't attach again. The garages I know use water with a bit of dishwashers detergent but ofcourse you are free to use whatever you want.
