As a lot of threads i followed ran out before i could find out how the OP fixed the problem, i just thought i'd reply to why my project bike wasnt running well after fully rebuilding the carbs.
I used aftermarket idle and fixed jets in the rebuild( rookie mistake no1), so i decided when it wasnt going great to replace the jets with the OEM parts i took out.
When i opened the float bowls i found dirt in them , i obviously fed bad fuel back into them after cleaning them (rookie mistake no 2)
It was still running rich so i vac synced the carbs this time at low rpm, i realised i also put too much oil in the uniair filter foam (rookie mistake no 3) hence the rich or choking.
After fixing all that and turning the idle screw out to 1 3/4 she runs nice and happy having being off the road for god knows how many years and the plugs are looking good. I want to thank " Two Tired" for all the effort and details in his threads without which i would still no doubt be down the shed scratching my head.
good luck and thanks.
Steve
