Author Topic: copper washers and domed nuts on F2 heads  (Read 546 times)
Offline mazingerzeca
« on: April 08, 2014, 11:52:19 AM »
Hello all.
I've searched through the forum and I'm a bit confused.
I am reassembling an CB750 F2 engine and I have 4 copper washers and 4 domed nuts for the cylinder studs. I've read that these ones go on the 4 studs which are closer to the cam chain tunnel (which should be 1, 2, 3 and 4 on my picture), but in other post I've read that are 5, 6, 7, 8 in the tightening sequence (my picture is the tightening sequence  from the factory book). So, could you light a candle? Which are exactly the studs in which I should put the domed nuts and copper washers according to my picture?
Thank you.
Re: copper washers and domed nuts on F2 heads
« Reply #1 on: April 08, 2014, 12:15:08 PM »
I'm at this stage of my build, too.
Per your picture, 5,6,7,8 are the correct ones.
You would have put o-rings on these studs before installing the cylinders.
Offline bytio
« Reply #2 on: April 08, 2014, 12:47:53 PM »
Your picture is not the correct one this one shows the domed nut and copper washer position
« Reply #3 on: April 08, 2014, 12:55:53 PM »
hmmm...kinda looks like 5, 6, 7 & 8 to me  ???
Oh sorry, you were just pointing out his picture was wrong  ;D
« Last Edit: April 08, 2014, 01:47:37 PM by flybox1 »
« Reply #4 on: April 08, 2014, 02:51:31 PM »
Done. Thank you very much.
