Am I the only one confused here? I've read on this forum about the Canadian 750 Nighthawk carbs fitting the CB750 (K) head. That's why I purchased a set that I haven't yet tried to use. Bear stated that the Australian equivalent to the Nighthawk carbs get used down under on our SOHC CB750's. He sent a set to Bill Benton to try. Mitchell has fitted a set of CB650 carbs to a 1973 K 750 head. TurboD says the CB650 and Nighthawk 750 carbs have identical spacing with the center two carbs having too wide a spacing to fit.
Can the manifolds be mixed to give us altered mountings? There are two different ones in use. On the
Mikuni RS34's & CB 750 topic Johno on page 4 has found Japanese aftermarket manifolds for K heads that are softer and more flexible for larger diameter carb ends. I've messaged him for more source information.
The FJ700/750 carbs also have been recommended previously on the forum. Pops has purchased a set and mounted them to a CB750 SOHC K head without problems.
There's not a lot of information about successful CV carb mountings to SOHC 750F heads. I've already posted the only source that I know of for aftermarket F manifolds. Dimensionally, I've never heard of any difference between F and K carbs for spacing or mounting. I've got a set of Mikuni 34 mm CV carbs reracked to fit my F headed SOHC 750 based motor. The mounting of the carbs is easier than finding the tuning needles and idle circuit changes to make them work with our motors. My Mikuni's got custom needles from Dyna-Jet in the early days. I don't know where to look currently for that kind of parts for obsolete carbs. The "performance" jet kits that are available usually include new needles for "modified" motors. That's what I used on Sam's K head Hondamatic - old 750 Suzuki CV carbs reracked and the stage 3 jet kit applied. Dyno time to get the right notch and main jet and you're down the road of your choice.
Do we measure everything for carb spacing and take pictures of our successes? Right now, I'm confused by one who has made it work and one who says it can't work. Anybody got some ideas?
