Author Topic: CV Carbs for 750  (Read 18701 times)
Re: CV Carbs for 750
« Reply #75 on: May 11, 2015, 03:02:15 PM »
I picked up a set of 34mm CV's from a Aussie model CBX750 today, as a bonus i got the whole bike in parts, except the engine which had self destructed due to cam chain failure,  all for the princely sum of $200 bucks..
« Reply #76 on: May 11, 2015, 03:47:13 PM »
Good luck with them, the ones I have are nowhere close to fitting.
A bit of tweaking to get them to fit but I already knew that.... ;)
Online Don R
« Reply #77 on: May 15, 2015, 06:57:29 PM »
 Has anyone tried juggling the boots, cyl to cyl and end for end? I made a weber intake fit once by swapping the boots around.
Offline hotdog
« Reply #78 on: May 21, 2015, 05:32:32 PM »
For those interested....
I recently purchased a set of Honda cbx750 CV carbs (34mm Keihin) to try for an upcoming project. This morning I thought I'd see how well they do or don't fit..?
Assembly was pretty straight forward, using the head I already have on the bench. New cruzin image rubbers were used with a little wd40, a pair of rachet straps and a small screw driver.
Very little effort was required using the straps to get them to pop straight in, plus little fiddling with the screwdriver.
1-4 lined up perfectly, 2-3 there was a little misalignment - but nothing severe, maybe 2mm each side.
Looks like they are a good CV alternative.
Follow me on Instagram - thelumpycam
Follow me on FB - The Lumpy Cam
« Last Edit: May 21, 2015, 05:40:23 PM by hotdog »
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
« Reply #79 on: May 21, 2015, 05:45:49 PM »
Nice.... ;)
Offline TurboD
« Reply #80 on: May 21, 2015, 06:01:33 PM »
Looks good. What year and model are those from exactly? Also can you measure the spacing of them, like in my "poor" Drawing? Lol
« Reply #81 on: May 21, 2015, 06:57:49 PM »
I have the same carbs, they are of an Australian model 1984 CBX750F..
Offline hotdog
« Reply #82 on: May 22, 2015, 10:32:35 AM »
TurboD, no problem, I'll get some measurements for you in the PM tomorrow, currently I'm at work on night shift and its 03:30am.
Offline TurboD
« Reply #83 on: May 22, 2015, 11:17:38 AM »
That would be great. Thanks
Offline hotdog
« Reply #84 on: May 22, 2015, 10:58:43 PM »
Turbo, hoping this is what you were after...?
Offline TurboD
« Reply #85 on: May 25, 2015, 05:16:06 PM »
That is helpful, thank you.
Offline bert96
  • past ride
« Reply #86 on: June 02, 2015, 03:43:36 AM »
Would like to see pictures of where you guys have installed your vaccuum ports.
Thanks
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
