Author Topic: Want Opinion on Ticking/Tapping Noise (With Video!)  (Read 1329 times)
Offline DaveBarbier
« on: April 09, 2014, 08:24:26 PM »
It seems like it's coming from the top of the motor...I think the exhaust side, but I'm not completely sure. I adjusted and double checked the valve tappets and cam chain. I've heard people say it's good to completely remove the cam chain tensioner screw and lock nut to clean it up. Then reinstall it. That it could be binding and not allowing proper adjustment. Does that sound sound? I have adjusted the timing and point gap too but this weekend I'm getting new points and condensers to be certain the timing and ignition is working properly.
Can anyone tell what this noise is? I also want to know if it's dangerous to run the motor or even ride it around. Have a look at the video, I'd love some help.
Thanks!
http://youtu.be/m-qKvc8cmGE
Offline LesterPiglet
  • 1977 CB550F2
Re: Want Opinion on Ticking/Tapping Noise (With Video!)
« Reply #1 on: April 09, 2014, 09:08:54 PM »
Tighten up your exhaust clamps, it sounds like it's blowing out.
If you need to find where tapping is coming from, get a long screwdriver and put the handle to your ear. Then put the tip on various parts of the engine. It acts like a stethoscope.
« Last Edit: April 09, 2014, 09:12:18 PM by LesterPiglet »
Offline 7fifty4
« Reply #2 on: April 10, 2014, 02:46:58 AM »
I had the same noise,( from what I can tell), I found that the exhaust flange bolts came undone on two cylinders.
Offline DaveBarbier
« Reply #3 on: April 10, 2014, 03:43:06 AM »
Ok, I'm glad you both said that. That's actually what I was thinking but I didn't want to sway it one way or the other. I ordered exhaust gaskets a couple days ago so they should be in soon. I can't tighten the bolts anymore. They're only 10mm and I don't want to over tighten them. They're definitely not loose, though.
Thanks!
1978 Honda CB550K
« Reply #4 on: April 10, 2014, 07:40:46 AM »
Can you switch to exhaust studs?  Really easy to do while your exhaust is off.  Then you can get a good torque on the nuts without fear of pulling threads...
Offline DaveBarbier
« Reply #5 on: April 10, 2014, 07:51:02 AM »
What do you mean switch to exhaust studs? There are already studs that the nuts go on. I must be misunderstanding you.
1978 Honda CB550K
« Reply #6 on: April 10, 2014, 07:54:51 AM »
Thanks!
1978 Honda CB550K
Sorry, understood you to be using bolts, that's why I suggested studs.
Offline DaveBarbier
« Reply #7 on: April 10, 2014, 07:58:07 AM »
Thanks!
1978 Honda CB550K
Ah, crap. Yeah I totally meant nuts, not bolts. Even to this day I mix them around accidentally.
« Reply #8 on: April 10, 2014, 08:07:32 AM »
No worries.  Hope the new ex gaskets are the fix.
Offline Airborne 82nd
« Reply #9 on: April 10, 2014, 10:30:39 AM »
Two things leak for sure and tapping valves but I run mine a little on the loose side the noise does not bother me better than to tight.
Offline DaveBarbier
« Reply #10 on: April 12, 2014, 01:16:18 PM »
Ok so just an update, I installed new gaskets and that did the trick. Quiet as a mouse...with a 4 cylinder engine strapped to it. Thanks for the diagnosis, dudes.
1978 Honda CB550K
