Hey guys,
I finally fixed the carb leak on carb one. My last problem now is cylinder 2 not firing at idle. She will only fire once i open the throttle. I have taken the carbs aparts to pieces and i have reassembled them back together after cleaning them. AFAIK, carb #2 is using all the stock parts (cleaned and reused),,
This is what I have done.
1/ cleaned carbs
2/ timing chain
3/ points
4/ checked for spark
5/ checked plugs after a ride and they were very good no black or white. but a nice bronze
6/ i played with the air screw (lean/rich mixture)
7/ synched the carbs
What am i missing? Could it be the idle jet is bad?
