It's been a while. My camera was being serviced so I haven't gotten as detailed pictures of my progress over the past couple months as I'd liked to. But here are some updates to my build. After getting the motor into the newly painted frame, things have been coming along at a good clip. I got an o-ring kit for the oil pump finally. All the o-rings for this bike were a piecemeal pursuit that was pretty frustrating. The oil pump o-rings came from seller "lonelystar" on Ebay. For most of the others I got a 500 piece metric set from Ebay for under 20 dollars. That covered me for stuff like the petcock and tappet covers and other little things. Finding anything metric, such as the dozens of rusty or stripped machine bolts and screws, is virtually impossible to find locally here, and has slowed my progress.
Once I had the bike upright I was able to tackle the electrical. I bought a wiring harness for the 500 from a member here which was in good shape, but the connectors for my electrical panel were of a different type- must have been a different year of manufacture. The panel had the 6.3mm tab type of terminals while the harness had the post type. I looked everywhere for the flat terminals these bikes used and could only find them for order from china with a month long wait to be shipped. Being the impatient soul I am, I removed the terminals from the original harness I had (which was cut to bits by PO) and soldered them to the new harness' wires. I also tested the rectifier and regulator and they seem viable.
I fitted the seat, electrical panel, battery box and the filter box. My carbs are complete and ready to go in. I'm going to make the vintage carb boots I have more pliable by boiling them with wintergreen oil before I do though. I also received bars, grips and mirrors so I can start on hooking the controls up (wires also cut by the PO). I'm going to run those wires through the cafe bars to hide them.
I think the next step will be to rebuild the front disc brake. There is little room for, because of the cafe bars, for the bolt to come out of the master cylinder. It looks like I may need a 45 degree banjo bolt. I'd like to use braided steel lines if possible. If anyone has a source for this stuff let me know. I want all the braking power I can get out of this old system. People around here refuse to use turn signals. Part of the lazy, friendly, take-life-as-it-comes attitude that comes with living in the south I guess.
![Huh ???](http://forums.sohc4.net/Smileys/default/huh.gif)
Anyway, here are some images:
