Author Topic: Cb350f butterfly/linkage  (Read 384 times)
Offline Versuspop
« on: April 17, 2014, 06:54:52 PM »
I am having a problem where if I pull the throttle ad let go it snaps closed fine. If I pull it just a bit, say just a bit past free play and let go, it sticks/closes real slow. It does this with the cables off and I am using my fingers to turn the butterfly. (?--the part that the cables attach to on the top of the carbs) I can manually close it the rest of the way.  The butterfly never touches the cam thing, unless I push it against it.
Ain't nobody got time for that.
Ian
Re: Cb350f butterfly/linkage
« Reply #1 on: April 17, 2014, 07:23:29 PM »
Clean them.  O obably just gummed up with road debris, oil and dirt.
Offline Versuspop
« Reply #2 on: April 17, 2014, 07:55:00 PM »
Clean what? Carb linkage? Everything looks nice and clean.
How much of what you think I should clean can I do without breaking them apart (and resyncing)
