Author Topic: 78k 8 signal removal.  (Read 856 times)
Offline Sdsbassist
  • Gus, Austin, MN.
« on: April 17, 2014, 09:04:08 PM »
Im taking off the lollipop front signals to go with something else...when I loosen the bolt and start to pull them off, they stop...
Any ideas?
Sent from my PC36100 using Tapatalk 2
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Re: 78k 8 signal removal.
« Reply #1 on: April 17, 2014, 09:15:09 PM »
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #2 on: April 17, 2014, 10:01:29 PM »
Tried to..and of coursr, nothing in manual. Thanks
Gus, Austin, MN.
Wobbly
« Reply #3 on: April 18, 2014, 12:44:40 AM »
There isn't anything to it, to put it in the manual. Completely remove the 6 x 35 hex bolt. Use a flat screw driver to loosen up the arm a little, slightly and carefully pull the gap apart a touch more. Pull off (provided the wires are disconnected).
If you take the signals off but leave the front ears on (i.e., lamp holders), it looks rather silly. But, I guess, everyone has a different taste.
