Author Topic: 1972 CB750 Steampunk(ish) Bobber Thing  (Read 212316 times)
0 Members and 12 Guests are viewing this topic.
Offline Noddy78
    • Atomic Contraptions
Re: 1972 CB750 Steampunk(ish) Bobber Thing
« Reply #625 on: November 23, 2014, 10:56:40 pm »
And also thanks for the kind words guys, I'm totally chuffed with them too. I'm now getting onto the varnishing, hopefully I can get the finish I'm aiming for. I've also resigned myself to quite a while until I get my dream workshop so I spent the weekend converting our storage space into something workable so I can at least start tearing the engine down and see what the PO destroyed there...
Offline Riceman
« Reply #626 on: November 28, 2014, 09:51:59 am »
Well after making it to page 8,I decided it best to start at the last page
and go backwards......
Keep building and posting Noddy
Have you checked out Ron Young Patinas?
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CB4QFjAA&url=http%3A%2F%2Fwww.sculptnouveau.com%2F&ei=trZ4VMHhFcewogT3rYH4Bw&usg=AFQjCNE0VvlRVayJg1UCojp-Uiwv6Jp-Iw&sig2=2J4kxFNn6p1iOnAb9fxXXQ&bvm=bv.80642063,d.cGU
« Last Edit: November 28, 2014, 09:54:30 am by Riceman »
Offline Noddy78
« Reply #627 on: December 01, 2014, 09:58:28 pm »
Sage advice for anyone braving this thread...
I have mate, I may end up utilising some of that too. Not sure as yet how "patina'ed" this one is going to end up being actually.
So.. engine tear-down over the weekend. Found just a little bit of metal in the engine...
The culprit:
It looks like the cam shaft had a blow out at some stage and the timing chain chewed up the valve cover... I can only assume the PO welded up the cam shaft and put it all back together (cam shaft was attached to the cam sprocket by only one bolt), including the stuffed valve cover and left all the bits of metal in the engine! But bugger it, that's what the oil filter is for, right!? ...
Luckily it looks like that did limit the damage, everything else actually looks OK. The only other suspect looking thing were these scratches on the upper crank case:
Thoughts?
So, I'm going to need lots of new bits! I'm thinkng 836 kit from Cycle X? What do you reckon?
I'm going to need about two thirds of all that anyway, might as well just go the whole hog...
« Last Edit: July 09, 2017, 05:53:00 pm by Noddy78 »
« Reply #628 on: December 02, 2014, 01:10:13 am »
Auch!
Is that a weld on the camshaft?
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #629 on: December 02, 2014, 01:23:43 am »
Looks like a PO just did a quick job to get it running and get it sold, without giving a shyte for whatever problems cropped up for the next owner. Gotta love some people ???
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline flatlander
« Reply #630 on: December 02, 2014, 01:56:55 am »
ouch that looks painful.
might be an idea to warn other buyers of this #@*$-head.
Online vfourfreak
  • Do you think that's wise
« Reply #631 on: December 02, 2014, 02:02:05 am »
That motor must have made a fearful sound in it's last few minutes of running !! A camshaft lathe of sorts.
I'd go for the whole kit also !
Kev
Offline Noddy78
« Reply #632 on: December 02, 2014, 01:51:46 pm »
I don't actually think the PO did anything maliciously, I'm pretty sure he was just incompetent. I have the Clymers manual he had with it, that's got all his notes etc in it (apart from "January 1992: Broom stick handle Frame Kit" and "June 2005: re-weld cam, shove it back in there without checking anything else"). He's evidently had the bike since at least 1984, and has tinkered pretty heavily with it. But that's ok, I bought it expecting to have to do almost everything, that was the point of getting this one... as I said way back when, before I got bagged out for destroying such a fine example of a CB750...
Offline Noddy78
« Reply #633 on: December 02, 2014, 01:52:22 pm »
That is exactly what it is.
Offline Noddy78
« Reply #634 on: December 02, 2014, 11:15:43 pm »
So, let's begin with the questions... Currently I measure the bore on my engine at a shade under 61mm (60.8mm), so basically stock. The cylinder sleeve walls measure roughly 3.5mm in thickness. So, if I'm looking at the 836 kit (which I believe is 65mm?) then I'm left with cylinder sleeve wall thickness of about 1.5mm or less. Now, this seems awfully thin to me... is this correct/what you would expect? Or do I have the dumb somehow?
Second question is, what cam do you think if I go the 836 kit? Cycle X have 1 through to 7 (http://www.cyclexchange.net/camshaftpage.htm) but I'm guessing I should be looking at 2 or 3, but which one? I'm not taking this thing to the race track or drag strip or anything, just after something reliable with a nice bit of poke. Thoughts?
« Reply #635 on: December 02, 2014, 11:38:59 pm »
dont ask questions just go the big kit man!,its a bit like re formatting a hard drive, it just wipes everything and starts fresh.
Offline Noddy78
« Reply #636 on: December 03, 2014, 12:19:47 am »
I bet you're just a riot at parties Dave...
« Reply #637 on: December 03, 2014, 12:24:44 am »
only pirate parties ahh!ahh!ahh!just bore the whole thing over new cam etc in one hit,no point pussy footing around at this stage,just don't use wooden pistons!just run a basic cam,too many guys over cam any engine.
Offline calj737
  • I refuse...
« Reply #638 on: December 03, 2014, 02:32:07 am »
CX-1 is all you'll need to get a good "poke" out of it. Correction: Dave's a riot wherever he goes, pirate ship notwithstanding.
Offline Blackfin5
« Reply #639 on: December 03, 2014, 04:56:30 pm »
Don't listen to Dave.....think bigger!  I hear JMR still has an 1000cc billet block available.  That will really make some steam.
Offline Syscrush
  • Sold. :(
« Reply #640 on: December 05, 2014, 07:20:13 pm »
I stopped clicking on this thread for a very long time.  I am glad I came back.  Those gauges are magnificent - good luck on getting that engine sorted out.
BTW - if you don't mind a suggestion about the wooden parts... If you apply some water-clear (refers to the color, not cleanup!) epoxy resin, you would have a very durable and chemical-resistant finish that can be treated the same as any other automotive surface like paint or chrome.
Offline Noddy78
« Reply #641 on: December 05, 2014, 08:44:23 pm »
Glad you made it back too! I don't mind the suggestion at all, unfortunately I'm already half-way through the varnishing process. I wanted that wooden boat finish, so I went with a wooden boat spar varnish. Horrible stuff to work with, but it's starting to come together and look the way I want it to. Probably not as durable, but will hopefully do the job after 10-20 odd coats...
Also, this:
« Last Edit: July 09, 2017, 05:54:22 pm by Noddy78 »
Offline Syscrush
  • Sold. :(
« Reply #642 on: December 06, 2014, 04:03:51 am »
3 is out of stock - get a 2 and be happy. :)
Offline Noddy78
« Reply #643 on: December 06, 2014, 10:24:53 pm »
Given how so far they're not answering any emails, it could be none at all...
« Reply #644 on: December 06, 2014, 11:22:58 pm »
youll be happy enough with a stock cam,some cam numbers are only bragging rights anyway?your detail is your bragging right,even if the overall design don't float that well with me,dont go out of your way for any special camshaft if you have a perfectly usable stock one on hand.
Offline Noddy78
« Reply #645 on: December 07, 2014, 01:48:14 am »
« Reply #646 on: December 07, 2014, 02:03:41 am »
ok,find a replacement,if you can get a stock one good,if its aftermarket don't try and gain power by ordering a hi po one,itll only end in miserable off idle and cruisabilty riding,some hi po ones only suit acceleration loads only and will not cruise.
Offline maduncle
  • Don't confuse me with a
« Reply #647 on: December 07, 2014, 03:19:07 am »
My gods - where have I been the last 26 pages?
I just went through a jumbo sized popcorn reading from page one, this is so much fun.
Noddy - I remember your first steampunk build as it was being done, you are very clever at using old stuff and at making new stuff to look old too.
Terry is right, I tried brass velocity stacks too, ran like crap but they looked cool on the F2 until I got the foam filter kit. I ran leather side panniers and had a cream and brass colour scheme - the bike was even called a 'High Tea Racer' as a sort of steampunk cafe racer.
Um - I better fess up here. If you Google 'maduncle steampunk' you will see that I get up to a bit of brass mischief too, although not for a few years now (I grew up  ;))
So anyway, I have another 44 gallon drum of popcorn oil on order and I am settling in for the mini series.
More drama than Game of Thrones!
CB750K2 (only slightly modified)
Offline maduncle
Offline Restoration Fan
  • My wife will never call me
« Reply #649 on: December 07, 2014, 04:04:40 am »
PS - now this one may call steampunk.
http://www.pipeburn.com/home/2014/12/04/ducati-900ss-typhoon-old-empire-motorcycles.html#.VIQ4sSjjZUQ
Nice bike and a pretty girl at the end of those threads as well.  But Noddy's gauges and headlight are better, IMO.
Noddy, great job so far.  Keep up the good work.  Really enjoying seeing the fruits of your labor.  And let me add my kudos on those gauges and the headlight.  Absolutely stunning work on those.
« Last Edit: December 30, 2014, 09:39:10 pm by Restoration Fan »
