Author Topic: 1972 CB750 Steampunk(ish) Bobber Thing  (Read 199409 times)
Offline Noddy78
    • Atomic Contraptions
Re: 1972 CB750 Steampunk(ish) Bobber Thing
« Reply #850 on: September 27, 2017, 04:14:05 pm »
Hey mate, that's pretty much the plan for mine. I don't like the 'capped' look personally, just looks like someone hacked off a bit of the bike (oddly enough), so I'll be doing the same thing you have. I assume you just welded in some tube cut in half(ish)?
Offline CBertels
« Reply #851 on: September 29, 2017, 10:08:13 am »
Just read through this monster of a thread.  Solid work from the OP.  The initial hating was a little ridiculous.  Good to see you are pushing through.  Can't wait to see this thing finished.
Offline BLAC
  • An espresso is a
« Reply #852 on: September 29, 2017, 07:53:18 pm »
Yep, I just cut a plug out of some spare tubing, shaped it pretty close, tacked around the outside and went to town with a metal file
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
« Reply #853 on: October 08, 2017, 01:55:45 am »
AH me hearties,when is this creation going to set sail?nice engine work there noddy.
Offline nvr2old
« Reply #854 on: October 08, 2017, 10:38:02 am »
I, too, await anxiously for new updates on this build.  Maybe one of the more creative on this site.  More, please...
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
Offline Noddy78
« Reply #855 on: October 15, 2017, 04:45:12 pm »
Right, well I finally got some work done this weekend...
A few clearances issues to sort out...
But at least it's starting to look like a motorcycle!
Offline ofreen
« Reply #856 on: October 15, 2017, 08:26:29 pm »
Yes it does.
Greg
'75 CB750F
Offline tshrey
« Reply #857 on: October 16, 2017, 07:14:43 am »
Did you make your exhaust or buy it?  Your collector location is exactly where I want mine to be.
Offline Noddy78
« Reply #858 on: October 16, 2017, 04:01:11 pm »
That's a bought one. Cycle X Rapid Fire http://www.cyclexchange.net/Performance%20Pipes%20Page.htm. Fitment is good, just sticks out further forward than I'd like (and from what I can tell, than it really needs to) so I'll have to modify it, but I'm sitting a fair bit lower than stock so I doubt it'd be an issue on stock heights.
« Reply #859 on: October 17, 2017, 06:46:24 am »
Looks amazing Noddy...
'74 "Big Bang" Honda 750K [836].....'71 Honda 750K project.....'76 Honda 550F.....K3 Park Racer!......and a Bomber!............plus plus plus.........
Offline Noddy78
« Reply #860 on: October 19, 2017, 04:04:43 am »
Thanks Stev-o, I'm pretty stoked with how it's coming together! Still so much to do though...
Offline 63SSRagtop
    • My stuff and friends toys..
« Reply #861 on: October 19, 2017, 10:19:19 am »
Have some cool sight guages i was going to use on a steam punk build on a GS550ES.. find some of these old compressor sight guages and could actually use copper pipe or possibly water pipe with joints for the wiring.. i was going to actually make the frame look like it was sweated together and color it like copper pipe.. think that would have been super coolio!
Offline Noddy78
« Reply #862 on: December 06, 2017, 05:30:24 pm »
Hey mate, so what happened to that build? Is it somewhere still in progress? I ended up copper-plating my last bike frame to get that look, looked great (IMHO). Oh, and funnily enough I have a sight-gauge that I'm hoping to use on this one too.
Ok, so house is nearly complete, work is getting a bit slow... must be bike time! I've been busy ordering all sorts of bits and bobs to get a good go at this thing over the Xmas break. I've got some custom fender blanks coming from Western Australia, I've shortened those pesky exhaust headers (just waiting on some bling before I weld them back together), stripped the tank and split it in two because I thought it was full of rust (it wasn't, but still needed to split it for other things anyway), learnt to lift-start TIG (how nice is TIG welding!?), and made some handlebar switches.. twice. Well, 1 and half times anyway. I think that's the bulk of progress so far...
Switch-housing attempt no. 1:
Sooo... attempt no. 2!
Success! And then my inherited el-cheapo bandsaw broke so I'm waiting on some new tyres for it to split the switch housings...
Online calj737
  • I refuse...
« Reply #863 on: December 07, 2017, 02:51:34 am »
Noddy - when you go to weld that tank back together, use Silicon Bronze wire instead of ER70. The SilBro is worked at much lower temperatures, so you won’t get nearly as much warpage, won’t blow through, and if you lay those dimes well enough, it looks great with a beautiful buff.
Offline Noddy78
« Reply #864 on: December 07, 2017, 02:37:40 pm »
Yep, great idea. I've been fiddling around with silicon bronze for some of the brass stuff (with not whole lot of success there) but works beautifully on steel. I hadn't thought of using it for putting the tank back together as I am planning to copper-plate it, but doing a quick search looks like plating on silicon bronze is fine, so that's a great idea. Probably be good for repairing the badge dents and stuff too.
« Reply #865 on: December 07, 2017, 04:58:31 pm »
I bet aesthetically, the silicon bronze rod fits right in with the rest of the project, too.  Win win.
Online calj737
  • I refuse...
« Reply #866 on: December 07, 2017, 05:35:31 pm »
Probably about 27-32 amps is all you will need too with SilBr wire.
Offline Noddy78
« Reply #867 on: December 10, 2017, 04:06:30 pm »
Cheers, mate. The tank is so thin at that point anything above about 20amps seems to blow right through the damn thing though! The SilBr is working OK though I think.
Fenders arrived yesterday, need to be shaped and modified to fit right, but it's starting to look like a motorcycle (just dropped a few other bits on there for mock-up):
Offline nvr2old
« Reply #868 on: December 10, 2017, 05:27:05 pm »
Call me crazy, but I think those fenders look really cool extra long.  Round off the ends, maybe roll a bead on the edge and you'll have a look unlike any other bike.
Offline JoeCooley
  • Long time lurker, but now I'm a
« Reply #869 on: December 21, 2017, 12:10:34 pm »
I agree! This bike is looking sweet! Good Job Noddy!
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
Offline Noddy78
« Reply #870 on: January 17, 2018, 04:44:50 pm »
Yep, I'm really liking the extra long fenders too, I reckon I'll go with it, clearances-willing. Turns out I got my measurements a bit skewiff so they're currently winging their way back to WA to get opened up bit more. Hopefully get them back in the next few weeks.
In the meantime, been busy over the holidays mostly with fabrication type stuff and haven't really taken many photos of the progress. Cut down the exhaust system and re-positioned and re-welded so it all fits nice and snug and hopefully leaves enough clearance for the front suspension travel (and added some extra bling). Finished off the switches and finally got the oil tank brazed together. Ended up getting me ol' dad to give me a hand on that one after a few botched attempts, but has come together beautifully (IMHO). Also been getting some more wooden bits together to start on the seat and for a few other detail pieces. Also been butchering the tank repair a few times, but I think I've got it sorted now, so that's the next thing to try and finish up. Hope is to have this thing on the road within 6 months... Aaannyyway, a few pics:
« Reply #871 on: January 17, 2018, 06:19:59 pm »
Beautiful workmanship...
Offline FuZZie
« Reply #872 on: January 17, 2018, 08:32:11 pm »
yea X10 Stev-o!
Offline JoeCooley
« Reply #873 on: January 17, 2018, 09:01:20 pm »
Just like artwork this thing is amazing. So beautiful
Offline Dr. Noisewater
« Reply #874 on: January 17, 2018, 09:04:53 pm »
WHAT?!
