Author Topic: honda 1981 xl500s  (Read 5120 times)
Offline stay youth
honda 1981 xl500s
« on: April 21, 2014, 04:14:06 PM »
Hello friends.
Need some help on getting this xl500s started. Its a new to me bike that wasnt running got for a real cheap. I rebuilt the carbs and cleaned all the jets and details. Got new foam filter. Changed the oil, converted the 23 to 21. Got the electronics all cleaned up. I'm getting fuel to the head and am I getting a spark, but just not getting those two at the same time. Can anyone fill me in how to check that valves are opening at the right time for it all to work? Or is there other bits i should be looking into? ANy details and comments are super helpful. Really excited to get this bike up and running.
thanks!
1976 cb400f
Online grcamna2
Re: honda 1981 xl500s
« Reply #1 on: April 21, 2014, 07:02:54 PM »
Do you have a service manual for it ? I have one in storage and could go get it to refer to if needed.
Offline stay youth
« Reply #2 on: April 22, 2014, 08:38:59 AM »
I do thanks, just dont understand this part about motorcycles too well. Knowing when valces should open when? When spark should be? How to adjust these two elements.
Thanks!
1976 cb400f
Online grcamna2
« Reply #3 on: April 22, 2014, 03:19:33 PM »
I'll get back to you when I pull that book out,possibly tomorrow...
Offline stay youth
« Reply #4 on: April 22, 2014, 04:08:20 PM »
No rush at all, just love your perspective. Really appreciate you taking the time!
1976 cb400f
Online grcamna2
« Reply #5 on: April 24, 2014, 11:22:29 AM »
Hi again,
I took a quick look and didn't see a book for the Xl500S in the first box i looked through;do you think you might see about ordering a Clymer service book for it ?
I saw used one on Ebay just a little bit ago.When you get the book,I'll walk you through the valve adjustment,etc. so you can do the tune-up.
« Last Edit: April 24, 2014, 05:11:01 PM by grcamna2 »
Offline stay youth
« Reply #6 on: April 24, 2014, 04:36:11 PM »
Ok great, thanks again for checkign and the help!
1976 cb400f
Offline stay youth
« Reply #7 on: April 27, 2014, 04:23:28 PM »
Ok got manual, Im having trouble adjusting clearance on intake valve. There is no space to put a feeler gauge on compression stroke. Once I get the clearance right, what would be the next steps? Seems like timing is the issue.
thanks
1976 cb400f
Online grcamna2
« Reply #8 on: April 27, 2014, 06:46:47 PM »
thanks
stay y,
put a few pics up here of the engine and the position of the alternator rotor and the timing mark and position the manual says for valve adjustment;I think it has a 4 valve head on this model ?
Offline stay youth
« Reply #9 on: April 27, 2014, 07:26:30 PM »
Ok will do sometime this week. Thanks again
1976 cb400f
Offline stay youth
« Reply #10 on: May 05, 2014, 07:17:05 PM »
I'm trying to set the valve gap but I can't even get a feeler gauge in. Yes it has four valves. Sorry didn't get any pics. My first issue is I can't get the t mark to line up with the case. Once it gets close piston swings back down again.  Seems like getting the valve clearances correct would be a good first step. Then disassemble top end and check out cam chain as timing seems to be off.  What are your thoughts?
Thanks !
1976 cb400f
Online grcamna2
« Reply #11 on: May 06, 2014, 05:42:50 AM »
A few pics will help;your valves may be tight as is usual when needing adj. but hey,that can be a pain trying to hold the crank on that 'T' mark w/ one arm(or knee) while trying to adj. ...  ;D  I know. You may need a person to help you hold it right on the mark while you adj. them;you have to adjust both intakes & both exhausts at the same time because they share a common valve lifter...you know in sequence like: 1-2.
Offline stay youth
« Reply #12 on: May 06, 2014, 02:18:44 PM »
ok coll sorry will try and get some pics and a set of free hands to adjust. I tried it once but mainly consisted of cursing! When i get them lined up will there be space i can slide feeler gauge in? Seemed too tight to slid anything in.
Thanks!
1976 cb400f
Online grcamna2
« Reply #13 on: May 06, 2014, 03:22:08 PM »
stay y,
You and a helper can get into the job w/ the book open and then post pics
Offline stay youth
« Reply #14 on: May 06, 2014, 05:34:43 PM »
Sounds good, time for my girl to get her hands dirty!
thanks!
1976 cb400f
Online grcamna2
« Reply #15 on: May 06, 2014, 05:55:14 PM »
Yeah,
When you set the valves be sure to follow the 'step by step' in the Service Manual and keep us posted here w/ the 'steps' & pics as you go.
Offline stay youth
« Reply #16 on: May 07, 2014, 09:33:29 AM »
OK will do, will be next week sometime I hope
1976 cb400f
