SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Honda CB 750F2 Running problems
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Honda CB 750F2 Running problems (Read 2787 times)
Emraa
Guest
on:
May 22, 2005, 01:33:24 PM »
I am currently rebuilding my old CB750 after being off the road for over 10 years.
I am having a baffling problem with the running.
It isn't running on no.2 (base carb) but running fine on others three. I have tried everything I can think of and would like to pick your brains - please help! It's getting very frustrating now!
Logged
Bob Wessner
"Carbs Suck!"
Really Old Timer ...
Re: Honda CB 750F2 Running problems
Reply #1 on:
May 22, 2005, 01:58:00 PM »
Ten years standing is a long time. When you say you've tried everything, did that include stripping and cleaning all the carbs?
Logged
Emraa
Guest
Reply #2 on:
May 22, 2005, 02:15:24 PM »
yeah, stripping and cleaning the carbs was one of the first things i did. it just won't take in the petrol. It's really baffling me!!
Logged
mcpuffett
Master
Reply #3 on:
May 22, 2005, 02:27:38 PM »
hi , have you got a good spark? fuel going to that carb ,then to that cylinder , have you tried easy start down that cylinder just to see if it will fire on it?
mick.
Logged
Honda CB750 KO 1970, Honda VTX 1300 2006, Lancaster England.
CB750F2
Hot Shot
Pat's first Honda 750 F2
Reply #4 on:
May 23, 2005, 04:44:21 AM »
Check spark, compression and that fuel is getting to No.2 carb by opening the drain on No.2 carb. If all is OK try opening the throttle and see if runs OK at higher revs. If it does recheck No.2 carb idle circuit and float level. Pat, from Nth Qld
Logged
Regards
Pat from Australia
Lumbee
Guest
Reply #5 on:
May 23, 2005, 05:59:09 AM »
...also check #2 plug and see if there gas/gas smell on it...
Logged
Emraa
Guest
Reply #6 on:
May 26, 2005, 12:20:43 PM »
Have tried all of the above! Any more ideas???
Logged
Dennis
Hot Shot
Reply #7 on:
May 26, 2005, 02:56:19 PM »
If you have fuel, compression and a spark visually sometimes the spark may not be strong enough. This is sometimes caused by the connections between the coil and the plugs.
Have you checked the spark plug caps (original Honda should be about 10k) and plug wires? Brand new spark plugs?
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
