Sorry to hear that.
BTW - how do you like your Avon tires?
I love them! They are very grippy and give good feedback!
Certainly an indication of oil being burned, but until you know whether it's top end or lower end, don't get too rattled.
Have you done a compression check yet? A leak down test? Are the valves adjusted properly? How badly does the engine smoke at WOT?
If it is only the top end, you could get a second head that is either good-to-go and run it while you rebuild yours, or vice-versa. If the amount of oil being burned is not so significant, then run the bike, top the oil regularly and rebuild over winter. As you remove the head during a rebuild, you'll undoubtedly go farther into the engine anyway.
I am going to get a compressiontester tomorrow and check. The valves are adjusted, yes.
I dont see smoke in the rearview mirror when I ride at full throttle, it seems to get worse when it idles. That said, it is drops of oil on the wheel and on the rear cowl after a ride.....
I have to buy a gasket set!
Thanks for replying guys!:-)
