Author Topic: 400f front forks  (Read 3415 times)
Offline Frenchmike
400f front forks
« on: April 23, 2014, 01:48:41 AM »
Hi all i,m new to your forum and i,m also new to my 1977 400f , my question is , I have replaced the front seals and used 10 grade fork oil , but the ride feels quite hard and not much dive under braking is this normal ? :-\
Offline MoMo
  • Ride like you're invisible
Re: 400f front forks
« Reply #1 on: April 23, 2014, 03:26:12 AM »
try ATF instead....Larry
« Reply #2 on: April 23, 2014, 04:08:27 AM »
It'd be good also to check the straightness of your fork tubes by loosening up the tubes in the triple clamps while all assembled and try slowly turning each fork tube by hand thru 360 degress and seeing if they'res any resistance while you do this.The upper tubes should turn in the clamps w/ no resistance; & check the alignment of your triple trees by eye to see if they're bent while the forks are in there.The only other thing could be your seals may still be a bit new/stiff...or your fork springs could be 'out of spec'.
Offline camelman
  • Man... Myth... Legend
« Reply #3 on: April 23, 2014, 06:43:33 AM »
The previous two posters nailed it. Excessive fluid will have an impact too. How'd you measure the amount of fluid you put in?
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
« Reply #4 on: April 23, 2014, 07:17:20 AM »
Camelman
+1`
Offline Frenchmike
« Reply #5 on: April 23, 2014, 07:38:52 AM »
Thanks for your replies, oil quantity as per manual, it was the first ride after overhaul, and not very far, but you could feel ever small bump in the road but it could be ridden with hands of the bars, so may be I should do a lot more kilometer be for making any changes.
« Reply #6 on: April 23, 2014, 07:49:28 AM »
Mike,
Did you try what I recommended ? if the forks & triples are not bent,you may be experiencing 'stiction' between your fork tubes and seals.
Offline chewbacca5000
  • I polish covers!
« Reply #7 on: April 23, 2014, 08:48:27 AM »
I rebuilt a set of 1971 or 72 cb750 forks and filled with an extra 30 cc of 10 weight fork oil and they are pretty stiff.  I wanted it to be a little stiffer anyway.  Manuel called for 230 cc I put in 250 cc.   Would that extra 30 cc of oil make that much of a difference?
Does not seem like that much at all.
    • http://forums.sohc4.net/index.php?PHPSESSID=c24ct3bm67177q1o5mq2p88gr1&/topic,60973.0.html
« Reply #8 on: April 23, 2014, 10:02:23 AM »
yes over 250 ml it  vill vent stone hard...there need to be some air floting in the valve..overfill make it hard..even with thin oil..that just mine idea..
  • I polish covers!
« Reply #9 on: April 23, 2014, 10:35:25 AM »
Thanks will drain a few cc!  Appreciate the quick reply.
Offline Jasondo
« Reply #10 on: April 23, 2014, 07:06:16 PM »
I have recently rebuilt my 400f forks. I believe 160cc is all it took. Its a small amount but extra is not better! Also if your tubes are straight I would then take them apart and clean the damper orifices on the piston. They may be clogged up?
Offline Frenchmike
« Reply #11 on: June 01, 2014, 08:25:18 AM »
Having ridden for about 60 miles to day, just to see if it would sort itself out , but still the same, but better over 70mph ,and at slow speed like riding over corrugated roof sheets
So i'm going to strip the front end down tomorrow and look at everything again
« Reply #12 on: June 01, 2014, 08:41:59 AM »
Mike,
They have the amount of fork oil specified in the manual for the CB400F to be 145-150cc after a routine oil change and 160-165cc after full rebuild.
Offline Frenchmike
« Reply #13 on: June 01, 2014, 10:04:56 AM »
Yes thanks for that, I have tried the oil levels as you said as well, right at the beginning
« Reply #14 on: June 01, 2014, 11:11:56 AM »
Mike,
You may just be experiencing the stiffness of new seals;what brand seals are you running ?
