Author Topic: Wheel bearing and powder coat  (Read 1131 times)
Offline stereosilence
  • 1975 CB550K
« on: April 24, 2014, 01:22:30 PM »
I want to powder my rear wheel. Should I replace the wheel bearing before or after or does it matter?
Offline greenjeans
  • 1972 CB750K2
Re: Wheel bearing and powder coat
« Reply #1 on: April 24, 2014, 01:37:08 PM »
After - typically they heat the part first to burn off any hidden grease or oil in the pores.  If the bearing is in there, out comes the grease.  Those seals will not keep the grease in.
Make very sure they do not powder the entire hub - I've seen it happen.
Offline Powderman
« Reply #2 on: April 24, 2014, 07:01:02 PM »
Are you talking a spoke wheel or an alloy wheel? Either way remove the bearings and throw them away and replace them. Mask the bearing races and prep and shoot the wheel.
  • 1975 CB550K
« Reply #3 on: April 28, 2014, 06:37:02 AM »
Actually, both a spoke and an allow wheel. The allow wheel is a 2005 R1 front wheel (fork swap). I am trying to remove the original wheel bearing from my 550's rear wheel and it is tough. Everyone says you have to heat it up to get it out. Any ideas for getting out the front bearing so I can use it (if heat is bad for the bearing)?
