Author Topic: Yet Another valve adjustment question - Error in manual? (400F)  (Read 9356 times)
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
Setting my valves just now and I am scratching my head on something. Here's my Honda shop manual, on setting clearances for the first set - the "O" valves:
Then it says, rotate the crank 360 degrees and set it on the very same mark and adjust the "X" valves:
Is this correct? I'd have thought i'd set TDC for the 2-3 cyls for this second set.
Lil help please, I am in the middle of this...
N.
« Last Edit: April 27, 2014, 10:22:27 AM by NobleHops »
I have a motorcycle problem.
Offline kajtek
Re: Yet Another valve adjustment question - Error in manual? (400F)
« Reply #1 on: April 27, 2014, 10:53:27 AM »
Its ages since ive done it, but i followed my own way by rotating to the t mark, wiggle the tappets to see which set are for adjusting (valve closed) then rotate 360 and do the other set. Bear in mind that the cam rotates 180 degrees every 360 of the crank. I see how the manual seems confusing..
1978 honda cb400f supersport
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: April 27, 2014, 11:40:57 AM »
Set on 1/4, rotate 360 and set on 1/4.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #3 on: April 27, 2014, 04:43:08 PM »
When looking from back of bike
Sent from my PC36100 using Tapatalk 2
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #4 on: April 27, 2014, 05:34:05 PM »
...and thats actually wrong, flip the tolerances.
Gus, Austin, MN.
Offline Airborne 82nd
« Reply #5 on: April 27, 2014, 06:02:31 PM »
What is actually wrong  ??? I think you are mudding the waters.
Offline thirsty 1
« Reply #6 on: April 27, 2014, 06:11:32 PM »
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #7 on: April 27, 2014, 07:55:56 PM »
Exhaust is 3
Intake is 2
Guess what I was out in the garage doing?!
Gus, Austin, MN.
Offline thirsty 1
« Reply #8 on: April 27, 2014, 08:27:19 PM »
Exhaust is 3
Intake is 2
Is there a update somewhere for this? I set mine to .002 and .002 as per the manual. Supplement?
Offline thirsty 1
« Reply #9 on: April 27, 2014, 08:29:16 PM »
where did the .003 exh. come from?
« Reply #10 on: April 27, 2014, 08:33:31 PM »
550's and 750's
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #11 on: April 27, 2014, 08:35:52 PM »
yes, sorry, should have indicated that.
Gus, Austin, MN.
Offline thirsty 1
« Reply #12 on: April 27, 2014, 08:36:47 PM »
550's and 750's
Thanks! Mr. Hops is working on 400. I thought I missed something along the way, paranoid - what was that..
« Reply #13 on: April 27, 2014, 11:15:32 PM »
http://forums.sohc4.net/index.php?topic=131823.msg1472413#msg1472413
scroll to the bottom. Bodi has it on point
Yep, I like to do it like that way. Less chance for confusion.
Offline lrutt
« Reply #14 on: April 28, 2014, 05:28:09 AM »
Every Honda I've ever owned has been .002 in and .003 ex. From 50's to 750's. I have never seen a motor with an intake measurement more than an exhaust measurement. I've seen some the same, and most where intake is less, but NEVER seen one where the intake was more. Think about this logically, the exhaust valve WILL run hotter and expand more, necessitating a little more clearance.
As for adjustment, and I've done this on just about every bike I own and it has worked for 40+ years. I just watch the valves and after the exhaust cycles and the cam lobes are away from the rockers, I check and adjust. Some of you may cringe but you are on the heal of the cam with the rocker and that's where you need to be. I don't worry about lining marks up perfectly etc. Just watch the valves. Works on my Honda's, Yams, Triumphs, Nortons, Guzzis, Ducati, etc. etc. etc.
Basically, don't over think it too much, understand the theory and watch the mechanicals work, it makes sense.
Offline NobleHops
« Reply #15 on: April 28, 2014, 11:54:25 AM »
Got it. Thanks guys.
