SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
Other Bikes
Topic:
S90 fork disassembly
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: S90 fork disassembly (Read 858 times)
Gentlemanjim
Full Member
on:
April 27, 2014, 09:08:47 PM »
My 1968 S90 has damper the rod/bolts at the bottom. How do I hold the top side to unscrew it?
Logged
tbpmusic
Expert
Re: S90 fork disassembly
Reply #1 on:
April 28, 2014, 09:37:17 AM »
With forks of that type it's best to loosen the bottom bolts while the tubes are still clamped up in the stem and top clamp.
That goes for the top bolt as well (where you pour the oil in) for models with the pinch-bolt tops........
Last Edit: April 28, 2014, 09:39:03 AM by tbpmusic
Logged
Bill Lane
Gentlemanjim
Full Member
Reply #2 on:
April 28, 2014, 09:41:01 AM »
Yes I did that. It's the bolt at the bottom of the leg that screws into the damping rod that I need to hold from above. It just spins now
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
Other Bikes
Topic:
