Clutch slipping?
Bingo. As for your compression numbers, they're not too bad, and you didn't say if your compression test was done hot or cold? (should be done at operating temperature) You didn't mention any mods, but if you've removed the OEM airbox and replaced it with pods etc, it'll run very lean, which will make it very hard to start.
The PD carbs have more issues with blocked pilot jets than mains, does it idle well on all 4 cylinders? If not, it may be that you've got one or more blocked pilot jets. Come back to us and let us know what mods have been done, how it idles, etc etc so we can help. Cheers, Terry.
