Hello All,
I've just bought a 1975 CB750F in ok condition with 20k miles. The bike starts ok but sounds rough. When I looked the bike over before I bought it, I felt that the #1 pipe was cold. I checked compression on all cylinders to make sure it wasn't in need of a motor rebuild(Fingers crossed).
Compression
#1 131 PSI Plug black soot and wet
#2 127 PSI Plug black and gray color Dry
#3 129 PSI Plug black and gray color Dry
#4 132 PSI Plug Black Dry
I first checked for spark by having the plug in the boot outside of the motor and holding near the motor, all clyinders have good spark.
I moved to timing, and was having trouble getting my timing light to flash when hooked either on the 1 or 4 cylinder, 2,3 worked great. I have a couple extra sets of coils to test with, I took a spare set with long wires and installed on the 2 and 3 cylinders because they were working correctly. This coil worked fine, so I installed that same coil on Cylinders 1 and 4. Still #1's pipe is cold when I run the motor. I reset the timing via my Haynes manual and a ohm meter to when the points were opening up, I'll get my bro's timing light for testing on Tuesday. Still no fire on #1. Point gap was rest aftereach time I moved the plate.
I checked valve clearances, all were close, and I moved the exhaust to .004, exhaust was a bit tricky, I had to bend up a feeler. Cylinder 1 had .002 for intake, and .003 for exhaust, and I reset exhaust to .004
I waited for the carbs for last, I bought a KZ650 from a guy who swore it needed carb work, but it just needed timing, and it's a screamer now, no luck with my CB yet.
I took out the carbs and dropped all the bowls and made sure that the jets didn't have a blockage, there was a bit of small rust particlies in all the bowls, but didn't find anything special in any of the carbs, I didn't adjust anything on the carbs, haven't read that far here on the forum or in my Haynes manual(little on the light side). Bike started in about 5 seconds after I got the carbs back in, and I was disapointed to find #1 still cold. I have the stockbox installed with a new airfilter, airbox fittings are tight for all carbs, I did reinstall carb #1 with a different connector to try something new.
I didn't take the top end off the carbs, I guess I'll have to look there for some junk.
From here I plan to time using a timing light, and then my carb might need adjusting. Points look like new, I think previous owner installed a new point plate setup trying to get #1 working
Anyone have a few pointers? I've got this far mainly by reading this forum, tons of good stuff here, so I'll keep searching.
I haven't checked the condensers, I figured if one of these were bad, I'd have trouble with 1 and 4, but 4 is running rich.
What adjustments should I try on the carb? The needle's were all in the same postion on all carbs.
I'm scratching my head a bit, thanks in advance for any tips you can pass along.
Good day
Brad
