Author Topic: Bicycle Terminology. Question.  (Read 2022 times)
« on: May 01, 2014, 09:57:59 PM »
This to settle an argument with some buddies.
When you are riding a bike, and either climb a hill, or are coming. To a stop.. You will be shifting,
 A up
 B down
 To clarify, you are going from a higher speed to a lower speed.
 What do you guys think?
« Last Edit: May 01, 2014, 11:58:34 PM by 754 »
Offline mrbreeze
  • Not your average
Re: Bicycle Terminology. Question.
« Reply #1 on: May 01, 2014, 11:10:55 PM »
I would have to say the same as any other vehicle. You would be down shifting. It will be harder on you to pull a hill in 10th than in 3rd. It will be the same thing pulling away from a stop. On a bicycle you are the engine.....you don't want to lug it.
MEMBER # 257
« Reply #2 on: May 02, 2014, 03:33:07 AM »
Down shifting.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #3 on: May 02, 2014, 06:34:03 AM »
Downshift.
You shift "down" to a "lower" gear.
--Evan
1975 CB750K "Rhonda"
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #4 on: May 02, 2014, 06:51:28 AM »
When on the road I downshift in anticipation of the lower crank rpms going up a hill.
Masochists shift up I guess?
Offline ChrisP.
  • Hold my drink and watch this...
« Reply #5 on: May 02, 2014, 07:09:57 AM »
Actually to get to a taller gear ("lower gear") the rear detailer goes up to the taller gears so it's shifting up to a taller gear ring but you are figuratively shifting into a "lower gear". Make since?
Chris P
1973 Honda CB750K3
Offline Blasbo
« Reply #6 on: May 02, 2014, 07:16:19 AM »
Down shifting, but the chain actually moves "up" to a larger sprocket.
Offline ChrisP.
« Reply #7 on: May 02, 2014, 07:17:09 AM »
correct
Chris P
1973 Honda CB750K3
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #8 on: May 02, 2014, 07:20:12 AM »
+1
While it's correct that shifting to a lower gear is the effect, several cyclists use the term shifting up.
I think this is the scenario Frank is dealing with.
« Reply #9 on: May 02, 2014, 07:24:37 AM »
correct
Only if you are talking about the rear sprockets.
I have a 21 speed, you could downshift to a smaller sprocket on the crankset.
Frank - shouldnt this be in your dikshunary thread?!
Offline ChrisP.
« Reply #10 on: May 02, 2014, 07:29:55 AM »
correct
Most (90%?) of your shifting is done with the rear unless you are stopping and then starting at the bottom of a hill, then you're just dumb! Ha! Ha!
Real men stay in the big ring on the cranks!
Sent from my iPad using Tapatalk
« Last Edit: May 02, 2014, 07:32:31 AM by ChrisP. »
Chris P
1973 Honda CB750K3
« Reply #11 on: May 02, 2014, 07:39:11 AM »
correct
That's not nice making fun of us girly men.
« Reply #12 on: May 02, 2014, 07:42:56 AM »
Or granny gear shifters!! You know who you are!
« Reply #13 on: May 02, 2014, 07:47:41 AM »
I am one.
Offline Maurice
« Reply #14 on: May 02, 2014, 07:48:02 AM »
You have it reversed: tall gear == slower spinning, harder, flat to downhill. Small gear == faster spinning, easier, hills, upwind.
The tall vs. small refers to the length traveled on a single crank revolution: big ring small cog this becomes tall, small ring big cog this becomes small.
Source: thousands of miles ridden and years of racing road, MTB and cyclo-cross.
« Reply #15 on: May 02, 2014, 08:02:04 AM »
The guy said the other me, it's going up the sprocket cluster, I said how do you know it isn't in your truck as well.
 I know lower gears are numerically higher, but most people on all other vehicles, consider lower gear= lower speed capability.
Offline ChrisP.
« Reply #16 on: May 02, 2014, 08:09:21 AM »
regarding the crank rings...
Chris P
1973 Honda CB750K3
Offline grumpy
  • ..... '73 750K3 .....
« Reply #17 on: May 02, 2014, 08:13:44 AM »
usually it's down = easier
but it can be interchangeable:
one can be "down in the 11" or "drop it into the 11"
typically we just say the number of teeth on the cog. EG "Dude, that hill killed me! All I had was an 18 and I was totally pedaling squares!"
« Reply #18 on: May 02, 2014, 09:53:49 AM »
Well shifting up 5 times into 1st gear, does not sound right to me..never did.
 And I agree the front cogs are more like selecting a range.
Offline Maurice
« Reply #19 on: May 02, 2014, 10:11:12 AM »
calj brings up a good point, nobody refers to shifting "up" or "down", it is confusing.
Just ride a singlespeed, grow some sideburns and wear tight jeans, and be done with it and those silly questions!
https://www.youtube.com/watch?v=Vn29DvMITu4
« Last Edit: May 02, 2014, 10:15:51 AM by Maurice »
« Reply #20 on: May 02, 2014, 02:09:41 PM »
correct
Maybe around Lake Conroe, but have you biked in the Hill Country lately??!
Offline ChrisP.
« Reply #21 on: May 02, 2014, 02:21:04 PM »
correct
I used to all the time when I was much thinner...
Chris P
1973 Honda CB750K3
Offline rtbmrgl
  • Got Points! Roseville, Ca
« Reply #22 on: May 02, 2014, 02:34:49 PM »
Unless your Lance Armstrong, then juice up and up-shift.
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
Offline riverfever
« Reply #23 on: May 03, 2014, 05:10:59 PM »
This. Minus the sideburns and those stupid jeans.
Online grcamna2
« Reply #24 on: May 03, 2014, 07:29:28 PM »
Bicycle gear charts are in inches traveled forward for each full 360 degree crank/pedals revolution;there is a decent 'sweet spot' in being in the correct gear for YOU w/ each climb,for most of us here that's the 'granny gear'  :-[ ....,until I start getting to climb more of these hills around Pittsburgh....,then I might have a more efficient 'spin' to 'torque it' in the next bigger gear w/ a lower cadence. I think to spin in a lower gear is better for me w/ my standard 170mm cranks that I've always used.
