I finally got out to my dad's house to do some welding on the rear fender. I pretty much destroyed the top part trying to remove it from the fender so we just welded two tabs on there. This made more sense for me too since my dad lives 6hrs away from the motorcycle. This gives me room to not be exact and I can fix it when I get home.
I got the original side plates off in pretty good shape and welded those on the chopped fender.
I chopped the front fender. things came out pretty good.
sanded and bondo for the fenders, now I can paint when I get home.
This is what the fender will look like mounted. We also made little brackets to hold the turn signals. Ignore the brown seat cover... I ordered black but it came brown and I'm waiting for the black to show up.
Front fender should look pretty good. I wish I would have cut it even on both sides but oh well.
I got my Ikon shocks in and I have to say i'm a little disappointed. Both mounting holes were stripped. Dave from Ikon mailed me a correct tap and I got them mounted but I thought I was buying a super quality shock... didn't really expect to have to tap things to make them work. shock also had some rust and chipped chrome. Overall, I'm sure I'll be super happy with the shock but I was disappointed in that.
the springs are really the only thing on the bike that is gloss black. I wanted the chrome but didn't want to spend the extra coin.
I got my new chain in after cutting the last one too short. I bought a 106 diamond chain. the shorter chain is absolutely too short. the 106 is absolutely too long. so does that mean I can only run a 104 length? seems like you should be able to run at least two sizes.
slack with 106 chain. swing arm is bottomed out all the way back.
This is with the 102 chain. It was so hard to get on and had about 1/2 of slack.
