Those are interesting points Dennis, Hopefully in the next few weeks ill have my funds together to get the rest of the parts from Hilborn. As well as a manifold made for my turbo. Draper is going to really dial in those two pieces of the job for me. I had spoken to him earlier after reading your post and even though it was hard to hear over the bad connection, he has a great understanding of the gearing,shifting,and traction control under boost.
For the Hilborn- I know I need the "A"ir valve, "S"econdary bypass valve, and "E"conomizer valve. Possibly a 2-way shut off valve, the metering valve that screws onto the fuel tank,and a fuel pump.As well as the drive from the fuel pump to the crank. I need someone to supply this piece. Hilborn had mentioned *Bailey Chassis Co.?
Mr.Draper will also supply the proper pill restrictors,springs, and shims to get where we need to be. I am currently waiting for a new point and condenser for the ARD. Didn't have any spark after testing vigorously, If it still doesn't fire ill replace the coil as well. all replacement parts found surprisingly easily and affordable on Ebay..
late nights as always, Thanks for reading!
