Author Topic: K2/K5 Drag project  (Read 120587 times)
Re: K5 Race bike/K2 Landspeed
« Reply #650 on: July 13, 2015, 09:10:21 AM »
Way to go Pops and Turtle  :)
Offline dragracer
  • CB750F Dragbike
« Reply #651 on: July 13, 2015, 08:48:05 PM »
TREY: If you ran 13.25 at 99mph W/ .05RT or less all day long = every time then those 8-9-10 second bikes would have to run you down at the 1319' LINE and most time their 125-170mph bikes would be breaking them out or them crashing if they tried to brake not to brake out. It's a BRACKET RACE not how fast can I go ......... they pay for the wins at the end of the day and not for your ET or MPH. At this past SATURDAY NIGHT OF FIRE me and the TURTLE HAD THE PACKED HOUSE ON THEIR FEET watching the HARE trying to catch the TURTLE and none did but the race was called with me and two other racers at 1:30 AM because of a curfew= we 3 split the money. I had me and the "TURTLE'S " picture taken by many in the staging lane and on the track with the win light in my lane.
PS. On your slow bikes after the 1320' do not slow down right away as those fast bikes trying to jam the breaks on not to break out tend to crash [ in 25 years I helped a few get up off the ground and picked up a broken bike and racer ]
POPS BK911 NHRA
Good job Richard. You're still my hero.
« Reply #652 on: July 13, 2015, 09:09:35 PM »
Still dealing with tuning issues here and there along with air shifter failures
Is this the same air shifter that Frank had problems with?
Offline SBR-CB400F
« Reply #653 on: July 14, 2015, 04:46:36 AM »
Well Done Trey, those are some good numbers. Get that 60' down into the 1.8's and that 12 will come  ;D I wish it was that simple too.
Adam
1975 cb400f, 14.435 @ 89.01MPH at Willowbank Street Series 28 March 2015
1976 cb400f Nostalgia Drag Bike.
1.871 @ the 60'
8.632 @ 78.44 mph over the 1/8.
13.822 @ 91.91 mph over the 1/4
1977 cb750f2 Resto Project
1973 cb750k4 Chopper project
1971 cb750k1 Restoration Project
1975 cb750f1 Drag bike
1.549 @ 60'
4.425 @ 330'
6.895 @ 98.05MPH  1/8 mile
10.993 @ 116.76MPH  1/4 mile
Offline dragracer
  • CB750F Dragbike
« Reply #654 on: July 14, 2015, 10:11:02 AM »
No. That's a system that Trey put together. With the number of miles on that bike, I'd think its more a potential issue with the transmission. Unless he didn't have sufficient air pressure in the tank to begin with.
Offline NalleyRacing
  • 1972 Cb750K dragbike Instagram: Drag_racer736
« Reply #655 on: July 14, 2015, 01:36:17 PM »
I noticed on the last pass that it failed that it still had around 100psi in the tank and still managed to slip into false neutral.
I put 140 in and ran again and all 5 gears pulled no problem. Cant seem to figure out what caused that failure. It happened earlier in the day as well.
I probably just need to get the MPS switch and go Electric/air and see if it helps..
« Last Edit: July 14, 2015, 03:50:09 PM by TreyAllen »
Offline dragracer
  • CB750F Dragbike
« Reply #656 on: July 14, 2015, 05:50:24 PM »
A loose chain or one too tight with an air shifter isn't a good combination either. Be sure its adjusted properly. After having trouble with mine not shifting and replacing a lot of internal and external components, I ended up replacing the air kill with an MPS electronic box with adjustable kill time. That did seem to solve the problem. Glad i had that box laying around from another bike.
Offline POPS 911
« Reply #657 on: July 15, 2015, 04:27:16 AM »
According to "GOT BRUCE " or " POWER by SAUER " use the MPS AND KEEP THE NITROGEN PRESSURE AT 120PSI , not 140PSI and he has set up more air [ nitrogen ] shifters on the many bikes he has built to win many races ...... bet that ..... or come to Columbus NTR on ANY SUNDAY and  all the PRO-BIKES will give you a BOX SCHOOL on the 1320'.
POPS BK911
Offline Old Scrambler
« Reply #658 on: July 15, 2015, 08:20:53 AM »
NITROGEN.............for steady pressure in the sun or shade................good for tire pressure too ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #659 on: July 24, 2015, 07:08:12 AM »
So..
There is a TnT session followed by a motorcycle bracket race at the local track today. Bracket race is import vs American!
I had to switch back to the peanut tank while I have the Honda tank sealed.. So much rust and paint in there kept clogging carbs over and over.. Put on peanut tank and finally had full bowls down the line..
Also my on board air compressor went out a few nights ago.. I had been missing 4th to 5th pretty regularly with 130psi as a starting point. Now my compressor in the trailer wont put out more than 130 and with this slow leak I can't seem to find ANYWHERE it probably wont even make it to the line before losing 10-30 lbs.. So I'm working on finding the leak today and attempting to find a compressor than can fill the tank to 150 or so between passes
« Reply #660 on: July 24, 2015, 08:54:26 AM »
Just footshift the damn. Thing.. Work on it at the beginning of the week.. Use soap and after to find the leak
 If you are bracket racing,. Having a faster time means less than being consistent..
« Reply #661 on: July 24, 2015, 10:27:04 AM »
I have thought about that too Frank.. I'm stubborn and love my air shifter as well as have removed the front pegs and use only the passenger.
I've got a few hours to test and tune this afternoon so ill try and see what I can do. I'll keep yall posted..
Weird thing is I've spent the better part of my day in silence adding 130lbs of air to the system to watch it dissipate down to less than 100 withen 15 minutes.. I checked every connection with soapy water and found no leaks??
« Last Edit: July 24, 2015, 10:32:01 AM by TreyAllen »
Offline TurboD
« Reply #662 on: July 24, 2015, 11:53:15 AM »
I agree, Foot shift that damn thing!!! ;D I hate to see racers lose good track time to parts malfunctions.. I foot shift everything, I went deep in the 8's without a air shifter. :)
Offline dragracer
  • CB750F Dragbike
« Reply #663 on: July 24, 2015, 12:47:59 PM »
Probably leaking from the exhaust port of the electric over air solenoid. Take the Schrader valve out, fill the lines with wd40, put the Schaefer back in. Pull the pin out of the shifter lever and press the air shifter button. Do this procedure at least 4 times.
Offline dragracer
  • CB750F Dragbike
« Reply #664 on: July 24, 2015, 09:42:26 PM »
Trey,
It just came to my mind that there might also be an issue with your shift cylinder. I remember now that you're trying to use that big deluxe air cylinder. That system has a huge exhaust port so it uses a lot of air on each shift. You really don't need that big cylinder-no one uses those anymore for that reason. Get the smaller air cylinder as soon as possible. I think you might already have the small electric over air solenoid. If not, change that to the smaller one as well.
« Reply #665 on: July 24, 2015, 10:28:31 PM »
Ugh SO MUCH FUN!!
And yes Frankie I've noticed lots of air being used on this shifter. It came from Kevin Drapers top fuel Harley so I'm not surprised. I used 150psi as a starting point all night and had no missed shifts.. Will replace with smaller cylinder ASAP though
« Last Edit: July 25, 2015, 05:38:37 AM by TreyAllen »
Offline dragracer
  • CB750F Dragbike
« Reply #666 on: July 24, 2015, 10:54:44 PM »
How did you do in the race?
Offline Bill/BentON Racing
    • BentON Racing
« Reply #667 on: July 25, 2015, 05:05:21 AM »
I'll let him update you, but he might be a member of the 100 mph club!! ;D K, Bill
BentON Racing Website
BentON Racing Facebook
« Reply #668 on: July 25, 2015, 05:37:28 AM »
Practice was great, something happened at the tree though. I'm not sure what happened really..
I noticed a few other glitches throughout the night on other peoples time slips and even saw a few pro trees go off during the race for some reason..
But when I went to launch I saw two yellows then a red ball before I even moved!
Not sure if my buddy got it on video or not.. I had been running really consistent 13.2x most of the night at 100MPH and even got one pass down to 13.07! Just on the edge of those 12's  ::)
Offline SBR-CB400F
« Reply #669 on: July 26, 2015, 05:48:01 AM »
Congrats Trey, they are good numbers for a 736. What were your 60' times??
What did you do differently on that 13.07 pass.
I too have had 2 yellows then the red light came up thinking I didn't move but looking back at the video I had slightly, it doesn't take much on a bike, leaving your visor up till the last second, lifting your foot up on the peg, selecting first gear, turning the fuel tap on  ;D all simple little things that should be done before bumping into stage. Good to have a routine
Adam
1.871 @ the 60'
1.549 @ 60'
4.425 @ 330'
« Reply #670 on: July 26, 2015, 07:17:56 AM »
Thinking back it came to me..
You guys know how many things go through your mind as you approach that tree
I normally ride into pre stage, rev up to 6-7k then slowly release the clutch into a shallow stage on the second bulb.
On the last pass I did it backwards. Didn't rev until I was in the second pre staging bulb and it pulled me forward ever so slightly I suppose
« Last Edit: July 26, 2015, 07:22:07 AM by TreyAllen »
Offline POPS 911
« Reply #671 on: July 27, 2015, 04:11:02 AM »
Both feet on the ground inline with the crank, Dave Schultz won many races sitting straight up until 60' and starting off with both feet inline with the crank = lean a little forward and your body weight might just give you a YOU LOSE RED LIGHT. Put a staging disc on that front wire wheel, gives you more roll out and less RED LIGHTS as you can own a COBRA and still lose at the line = right BILL ? ET & MPH don't mean #$%* when you lose at the line, you seen my real home made practice tree with the roll out in the clutch lever. Even a 500 mile NASCAR RACE can be lost by .005 second at the win line just ask Eric Jones !!!!!
POPS BK911 NHRA
    • BentON Racing
« Reply #672 on: July 27, 2015, 04:29:54 AM »
POP's,  I'm capable of losing anywhere!  Haha.Lol.  But good advice Trey! Keep up the good work!! K, Bill
Offline joe p
« Reply #673 on: July 27, 2015, 05:48:02 AM »
I ran the big air cylinder from MRE for years without any problem. They said not to run over 120 lbs in it or it would damage parts and it would not shift right all the time after that.
P.S. I agree with 754 and POP's after 35 years of drag racing I can tell you going fast has nothing to do with winning in Pro ET and Street ET.
« Last Edit: July 27, 2015, 05:57:14 AM by joe p »
« Reply #674 on: July 27, 2015, 07:51:28 AM »
If I'm being honest all the way around I realized recently that I truly want to go fast. I want to feel thoroughly frightened when I crack the throttle open. I love CB750s to death and feel like I have a good advantage in bracket racing with mine! Once I dial this bike to a low 12 or high 11 ill be finished with tuning for speed and work on keeping it consistent..
That being said I am working on getting a 1000RR to play with for local heads up racing and eventually Pro $$$treet
There is only one turbocharged CBR1000RR that runs in Pro street right now and I've seen it put out a 6.98 pass @ Valdosta! I can't remember his name, but his dad used to race too if I'm not mistaken.
