Author Topic: K2/K5 Drag project  (Read 108761 times)
Re: K2/K5 Drag project
« Reply #975 on: February 07, 2016, 07:40:54 PM »
Since you've already changed the coils and plates with the same results, you might want to check the rotor; a bent advancer bolt might be causing too large a gap with the 2-3 pick-up?
« Reply #976 on: February 08, 2016, 12:47:29 PM »
 If you change to points and footshift, you could have had, a hundred runs behind you..
Offline hotdog
« Reply #977 on: February 08, 2016, 02:00:45 PM »
That's cruel....but probably true.
Trey if your Dyna s is toast consider a pamco as another inexpensive hall effect ignition option.
Or points....
Got rid of that air shifter yet..?
Sent from my HTC_M9u using Tapatalk
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
Offline NalleyRacing
  • 1972 Cb750K dragbike Instagram: Drag_racer736
« Reply #978 on: February 08, 2016, 02:41:23 PM »
Oh yeah air shifter worked fine on all the passes.. It was slightly binded before..
Have a foot shifter in my box just incase.. Im gonna try a set of points and see what we have
« Last Edit: February 08, 2016, 02:49:03 PM by NalleyRacing »
Offline dragracer
  • CB750F Dragbike
« Reply #979 on: February 08, 2016, 03:02:44 PM »
I DID NOT fabricate those air shifter brackets for that big air shift cylinder you were using, so I'm not surprised it was in a bind. Now get rid of that damn big air cylinder and get a small one. Please!!!
« Reply #980 on: February 08, 2016, 03:36:38 PM »
10:4 Frankie.. Ill be at Bills house all weekend so im gonna dig around and see if we an find one laying around the batcave  ;D
Offline Bill/BentON Racing
    • BentON Racing
« Reply #981 on: February 08, 2016, 05:18:52 PM »
Well, we got a little trip planned, remember that "Grey Bike"?
Yep Saturday, I'll be in the seat!  ;) ;D, Bill
BentON Racing Website
BentON Racing Facebook
    • BentON Racing
« Reply #982 on: February 08, 2016, 05:26:18 PM »
Been busy, worked til 3 am Sunday,  but we going back together!  Purple Rain, what big holes you have!
« Last Edit: February 08, 2016, 05:28:45 PM by Bill/BentON Racing »
Offline BPellerine
« Reply #983 on: February 08, 2016, 05:37:25 PM »
you going after a grey ghost??haha billp
1978 CB 750K ard and webers
another anfob
Offline dragracer
  • CB750F Dragbike
« Reply #984 on: February 08, 2016, 05:52:41 PM »
Naw, a red one. Lol
    • BentON Racing
« Reply #985 on: February 08, 2016, 05:57:06 PM »
Nope, this "grey bike" just a little quicker than the one POP'S mentioned a couple posts before! ! Hehe! Lol, Bill
    • BentON Racing
« Reply #986 on: February 08, 2016, 05:59:11 PM »
Hint number two, it resides in Winston -Salem , NC!
« Reply #987 on: July 02, 2020, 12:13:56 AM »
Trey, if it shifts fine with your foot and don't pop out of gear, it's probably your air shifter that is not set up properly.
Sam. ;)
Sound familiar Frank? ;)
Re: K5 Race bike/K2 Landspeed
« Reply #988 on: July 02, 2020, 12:26:17 AM »
I noticed on the last pass that it failed that it still had around 100psi in the tank and still managed to slip into false neutral.
I put 140 in and ran again and all 5 gears pulled no problem. Cant seem to figure out what caused that failure. It happened earlier in the day as well.
I probably just need to get the MPS switch and go Electric/air and see if it helps..
A loose chain or one too tight with an air shifter isn't a good combination either. Be sure its adjusted properly. After having trouble with mine not shifting and replacing a lot of internal and external components, I ended up replacing the air kill with an MPS electronic box with adjustable kill time. That did seem to solve the problem. Glad i had that box laying around from another bike.
I can't find the original thread, but I know we've had the same discussion about air shifters before, Frank.
Offline dragracer
  • CB750F Dragbike
« Reply #989 on: July 02, 2020, 07:26:25 AM »
Yeap. I haven't forgotten.  I adjusted the kill time. Its not popping out of gear.
