Author Topic: 1972 CB500K - Resto-Mod  (Read 36996 times)
Offline Oddjob
Re: 1972 CB500K - Resto-Mod
« Reply #25 on: June 21, 2014, 06:59:43 AM »
Bit of oil will be fine.
Offline onetruepunk87
« Reply #26 on: June 21, 2014, 12:09:58 PM »
Offline gonnarideagain
  • Last rode or turned a wrench in '75.
« Reply #27 on: June 21, 2014, 12:16:53 PM »
Yo! I can't get my carb unit to release off the intakes!! I'm a 66 y o "newbie" that made it #1 on my bucket list to ride again (not since '70's)!! I got everything loose and the unit is off the airbox np but, the intake side gives/moves but won't release! Am I missing something (entirely possible). Thnx & good luck with your's. BTW, mine's a '72 cb500K1 Four "barn find" not reg. since the '80's. Later, Paul. ;-)
Paul
« Reply #28 on: June 21, 2014, 12:32:59 PM »
Hey Paul, it's never too late to start! Is your airbox all the way out or just disconnected? Taking it out will give you some room to work the carbs off. You can try taking a heat gun to the carb boots to try to get them to flex more. Just keep rocking the carbs up and down while pulling back and they should give way. Good luck with yours and get a build thread going, there's loads of knowledge to be gotten from everyone here.
« Reply #29 on: June 22, 2014, 09:16:07 PM »
Thnx, man. I'm in WAY over my head and the 2 differant owner's manuals are next to NO help! They ASSUME you , the user/reader, have a working knowledge & omit things that are important, like disconnecting 2 lines UNDER the carb unit to remove it (I found them by sheer luck). I made an internet bud who's 61 & been a  bike-builder since 18 from Pittsburgh but he only goes online 1 time weekly! Anyway, he suggests finding/using a piece of wood to wedge between the intake & boots and litely tap with a hammer while jiggling (am I an octopus?). I got a very small amount of tools and a TORCH OR HEAT LAMP AIN'T IN MY INVENTORY (MAYBE A HAIRDRYER ON HIGH SETTING?). Sorry, just realized "caps lock" was on.  Oh, btw, I don't have a "smart phone" or digital cam for pics either.  SS $ only goes just so far. Weather permitting, I'll try again tomorrow (took today to recuperate my sore as hell old frame)  Thnx for the encouragement & tip(s). Later, Paul. ;-)
Paul
« Reply #30 on: June 24, 2014, 08:38:00 PM »
Somehow all of my money mysteriously turns into motorcycle parts  ???
With all of this and some engine oil seals on the way I should start getting busy.
« Reply #31 on: June 30, 2014, 09:40:44 AM »
It's out!
« Reply #32 on: August 03, 2014, 07:13:51 PM »
Hey guys, just checking in to let you know I'm still here. I know I haven't posted in a while but I am still chugging along, slowly but surely. Time and money is a little tight, but I'm doing what I can. I swear I've been working on it, here's proof.
Also managed to track down an extra brake caliper and mount for my dual disk set up.
« Last Edit: August 03, 2014, 07:31:04 PM by onetruepunk87 »
Online Stev-o
« Reply #33 on: August 03, 2014, 07:52:33 PM »
All looks good.  Are you painting or powder coating the bits?
« Reply #34 on: August 03, 2014, 08:06:57 PM »
Thanks. I'm painting the frame and other pieces with Spraymax 2k gloss black paint.
« Reply #35 on: August 18, 2014, 09:49:49 AM »
Finally got around to drilling out my rotors. I've been putting off painting everything because I want to do the inside of the rotors with the same Spraxmax 2k paint as the frame. Once the can is activated you only have a 12 hour window before it's trashed, so I want to get everything in one shot.
I've got to chamfer the holes still but the hard part's done. After that I can prime it and, weather permitting, paint it this weekend.
« Reply #36 on: August 21, 2014, 06:38:49 PM »
Chamfered with a counter sink and deglazed with some brake cleaner and a palm sander.
Offline Radam
  • taco racer
« Reply #37 on: August 21, 2014, 09:31:07 PM »
Looking sweet! I just picked up a 500 yesterday so this thread will help me heaps! Still not sure how deep I'm going to go in restoring it. Starting it is first in line. Keep it up!
Offline 2strokeTrush
  • Can you get that back together sonny?
« Reply #38 on: August 22, 2014, 07:41:24 PM »
We match ;D
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
« Reply #39 on: August 22, 2014, 10:45:19 PM »
Radam - Get a thread going and maybe we can help each other along the way. This bike pretty much needed to be stripped down all the way to nothing and built back up. The pictures make it looks a lot better than it was. I'm pretty much only using the frame and the engine. Everything else is basically being replaced with CB500/CB550 parts I've been picking up either on here or on Craigslist/eBay.
2strokeTrush - I've been following your threads, yours was way cleaner than mine, shame the clutch was screwed up. Hope you can sort that out or use one of your new 550's in it's place.
« Reply #40 on: August 23, 2014, 02:46:33 PM »
Yeah it was clean, that what made me even more pissed when the Clutch went to Hell....I pick the new 550's up hopefully Tuesday so we will see what happens from there!  Looking good my friend!  ;D
« Reply #41 on: August 30, 2014, 12:50:56 PM »
Frame and other small parts are painted! I underestimated how much paint I needed and ended up running out midway through painting :o Oh, well. I had to order more paint and it finally came yesterday. Here's everything all finished.
My next step is the engine. I've been scrubbing grime off of it all day today. It's getting pretty clean but it'll have to be spotless for painting, so I've still got work to do. I've also got new gaskets, oil seals and stainless hardware to go with it. Not sure how deep I'm going into the motor so I probably won't use everything in the gasket set. I ran into a SNAFU trying to take the cylinder head cover off though. I removed the breather cover, the two small side covers, the tappet covers, and all the bolts and screws. As soon as the tension was released the front separated from the head but the back side won't lift. From the diagrams it looks like there are two dowels holding it in place. Any tricks on separating the cover from the head? I put some pb blaster in where the dowels are and now I'm just waiting for it to soak in.
Offline jaguar
« Reply #42 on: August 31, 2014, 08:15:25 AM »
Cool project.
Going to polish the aftermarket finned engine covers?
« Reply #43 on: August 31, 2014, 11:13:00 AM »
Thanks for the tip, cal. I took a break from it yesterday after I got stuck, I'm gonna try and get back at it today to see if I can pull it off.
Jaguar, the finned covers were pretty beat up. Both have bottom fins broken off, the points cover had an big hole covered by a washer to keep it in place, and a chunk came out of the stator cover when i took it off the bike. I got a stock points cover off ebay and I'm working on tracking down one for the stator. I'm cleaning up the tappet covers and using them for now since they're in good shape but I might replace them with stock ones eventually, just because I like the look better.
« Reply #44 on: August 31, 2014, 01:32:37 PM »
Just for clarification, you did release all the tension on the tappets themselves correct?
How do you that, turning the advancer? This is all the Honda manual says
« Reply #45 on: September 01, 2014, 08:26:27 AM »
Got it! Thanks guys.
« Reply #46 on: September 02, 2014, 06:41:29 PM »
I burned out a couple dremel wire brushes and got rid of all the chipping paint and oxidation on the cover, I stayed away from anywhere that will have a seal.
:P
« Reply #47 on: September 04, 2014, 05:53:55 PM »
Parts keep coming in!
I got these from fellow member, Chaser60, last week
These came in yesterday, unfortunately the tubes and rim strips won't be in until next week.
And all the way from Germany, this came today.
« Last Edit: September 04, 2014, 06:08:05 PM by onetruepunk87 »
Offline CoolerKing
« Reply #48 on: September 06, 2014, 07:36:43 AM »
Ich mag die neuen Aufkleber
« Reply #49 on: September 07, 2014, 05:01:54 PM »
Engine sneak peek! Still have to polish the fin edges and put everything back on. Should look sweet with all the polished aluminum pieces and new stainless hardware.
