Author Topic: 1972 CB500K - Resto-Mod  (Read 32153 times)
Offline onetruepunk87
Re: 1972 CB500K - Resto-Mod
« Reply #50 on: August 31, 2014, 01:32:37 PM »
Just for clarification, you did release all the tension on the tappets themselves correct?
How do you that, turning the advancer? This is all the Honda manual says
Offline calj737
  • I refuse...
« Reply #51 on: August 31, 2014, 02:14:30 PM »
If that means that you did not because it's not listed in the procedure, then I understand. But, to avoid bending a valve, release all tension on the valves. This too could be preventing the cover from releasing as it's tweaked against a cam lobe.
« Reply #52 on: September 01, 2014, 08:26:27 AM »
Got it! Thanks guys.
« Reply #53 on: September 02, 2014, 06:41:29 PM »
I burned out a couple dremel wire brushes and got rid of all the chipping paint and oxidation on the cover, I stayed away from anywhere that will have a seal.
:P
« Reply #54 on: September 04, 2014, 05:53:55 PM »
Parts keep coming in!
I got these from fellow member, Chaser60, last week
These came in yesterday, unfortunately the tubes and rim strips won't be in until next week.
And all the way from Germany, this came today.
« Last Edit: September 04, 2014, 06:08:05 PM by onetruepunk87 »
Offline CoolerKing
« Reply #55 on: September 06, 2014, 07:36:43 AM »
Ich mag die neuen Aufkleber
« Reply #56 on: September 07, 2014, 05:01:54 PM »
Engine sneak peek! Still have to polish the fin edges and put everything back on. Should look sweet with all the polished aluminum pieces and new stainless hardware.
« Reply #57 on: September 09, 2014, 06:51:08 PM »
The downside to polishing is that once you do one piece really good, you have to give every other piece the same treatment.
Offline Tews19
  • I am no
« Reply #58 on: September 09, 2014, 07:13:48 PM »
I have a chrome brake stay plate never used before. I plan to list in the for sale section but if you are interested I can send you a pic via pm.
1970 Honda CB750 survivor.
« Reply #59 on: September 09, 2014, 07:58:06 PM »
Brake stay plate??
Offline MickB
« Reply #60 on: September 09, 2014, 08:18:49 PM »
Tews please send me a photo
MickB
Offline MickB
« Reply #61 on: September 09, 2014, 08:21:33 PM »
OTP lacquer your polished alloy with the POR15 clear, it'll keep it shiny and you'll never have to polish it again  - guaranteed not to yellow or crack.
« Reply #62 on: September 09, 2014, 08:34:58 PM »
I PM'd Tews because, like Steve-o, I'm not sure what he means by the plate.
Mick, thanks for the tip on the aluminum, I'll look into it. It would be a a shame to do all that polishing for nothing.
Offline MickB
Offline Tews19
  • I am no
« Reply #64 on: September 10, 2014, 04:40:02 AM »
Brake stay plate??
Lol brain fart... the rear brake plate.
« Reply #65 on: September 10, 2014, 09:12:36 PM »
Brake stay plate??
Rear brake panel
Offline Tews19
  • I am no
« Reply #66 on: September 11, 2014, 11:44:52 AM »
Panel? It's not a computer board! I like plate!
« Reply #67 on: September 11, 2014, 03:54:39 PM »
Part number 43100-319-000, Rear Brake Panel. I'll be damned.  ;)
Offline Radam
  • taco racer
« Reply #68 on: September 11, 2014, 09:34:18 PM »
I'm glad that got settled!  ;)
« Reply #69 on: September 13, 2014, 04:05:23 PM »
Sanded my fins and mocked things up. I have to swap in some fresh gaskets and go grab some anti-seize for my stainless bolts tomorrow so i can wrap things up on this and get it back in the frame. I think after this I'm going to start work on the tank and side covers while it's still warm enough for paint.
What do you think?
Offline MickB
« Reply #70 on: September 13, 2014, 04:22:45 PM »
Look'n good OTP, looks way better than all black, it really highlights the head, the fins, breather and tappet caps.
« Reply #71 on: September 13, 2014, 05:08:46 PM »
Thanks Mick! I wanted to do something different since my 750 engine is the stock aluminum color. Straight black on it's own I thought would be too dull, though. This low gloss black with the polished aluminum really pops out at you though. I'm really happy with how it came out.
« Reply #72 on: September 13, 2014, 05:09:13 PM »
Looks great!   I need to do a black motor....
« Reply #73 on: September 13, 2014, 10:00:53 PM »
I love the sanded edges on the head fins.
Offline MickB
« Reply #74 on: September 13, 2014, 11:20:10 PM »
OTP I reckon you aught to sand the fins on the barrels also, it'll be even better. If you don't like it - just re spray them
