Where will the grease ooze out when "it's full." Mine started coming out between the dust cap and swing arm. I just installed the bronze bushings and packed grease in there so there wasn't much room. I double checked the tightness of the swingarm bolt, and also just checked the lateral movement of the swingarm to make sure it was tight.
I just wanted to make sure this was normal, and if not, where should it be oozing out?
Also, is it too late to drill, tap and install screw in zerks? I assume it's not the best to do while in frame? I can always do this next winter, but probably should have just did it when I did installed the bronze bushings.
