My '76 cb550f is running better than it has been for a while, but i'm still having some odd
issues with it. I checked the carb and timing faqs, but this seems to either overlap both
(possible) or not exactly fit in either. It was running on three, until I located a broken part
in the carburetor rack and replaced it. Now it feels flat when running at any constant speed, and kindof
feels weak and sputtery.
Now here's the odd part.
a) unless it's been sitting for more than a week, it starts first kick (i don't use the electric start).
b) it idles very smoothly and reliably right at 1k.
c) it is very responsive to the throttle, and accelerates quickly and smoothly.
Lately i've been mostly riding in the city on short, residential blocks, so i'm usually in 1st and 2nd. If I
engage the clutch and suddenly open the throttle, it takes off admirably, and then between 4k and 5k
(if i level off on the speed) it feels like it's missing on one or more cyls. If i kick it to 2nd and accelerate
again, it picks up and accelerates smooth as silk again.
It doesen't seem too specific to RPM, since if i'm going slower in each gear it still feels missy and sputtery.
I have new main and pilot jets and a new dyna S ignition, which seems to have improved it
greatly from last year when it wouldn't run without the choke on full. The needles are clipped in
the middle position, and the vacuum is set pretty closely on each cylinder. Timing was done
static, and i'm using the stock airbox and 4 to one supersport exhaust.
I feel really close to having it running perfectly, but i'm hoping for some advice as to what
should be tweaked first so as to save myself time and sweat. I'm also concerned that since
it seems to be happiest while accelerating, that i'm likely to get pulled over by milwaukee's
finest.
Thanks!
