Author Topic: Carb Tuning Advice CB550k  (Read 8213 times)
Offline DaveBarbier
« on: May 12, 2014, 04:35:55 AM »
So you guys can point me to the right post at anytime, but I looked around and couldn't find any info for my specific set up.
My bike is pretty much stock right now. Stock 4-4 chrome exhaust, stock air box with UNI filter. I have an unknown 4-1 header (maybe the stock 4-1 that came on some 550's? I don't know.) with an 18" Dime City Cycles Stainless Steel "Quiet-core" Universal Cone Muffler that I intend to put on the bike. I am also keeping the stock "plenum" that goes between the air box and carbs and putting a K&N filter directly on that with a bracket I made. See picture.
Where do you guys think I should be starting with jets and needles and all that stuff? Right now the bike feels like it runs well. Starts right up, idles good, revs good and has good power all throughout the RPM range.
I haven't opened up the carbs yet to make sure they're stock. The PO never said anything about them being altered and everything else is stock on the bike. My carbs are PD 46c.
Need any other info? I don't know much about carb tubing but am trying to learn as much as I can.
1978 Honda CB550K
Re: Carb Tuning Advice CB550k
« Reply #1 on: May 12, 2014, 04:41:19 AM »
Well, there's your answer.
Ride on.
Offline DaveBarbier
« Reply #2 on: May 12, 2014, 04:48:34 AM »
Ride on.
But it's not subjectively "cool" enough! It has to be cooler. I'm doing this because I'm also moving the electrics under the seat and fitting a smaller battery. Cafe, minimalistic appearance, empty triangle under the seat with no side covers. I'm that kind of guy.
1978 Honda CB550K
« Reply #3 on: May 12, 2014, 04:59:22 AM »
Ah, I see... you can expect quite some people that are interested in your stock 4 in 4.
Offline DaveBarbier
« Reply #4 on: May 12, 2014, 05:28:35 AM »
I know. After I get this new setup all situated I'll part with them. All the more reason for people to help me, haha. I won't use them so I'd rather they go to someone here.
1978 Honda CB550K
Offline Bankerdanny
  • Endeavor to persevere
« Reply #5 on: May 12, 2014, 08:34:07 AM »
You will probably need to do some trial and error tuning (a pain since changing the jets with the carbs on the bike is very difficult).
I would assume you will need to bump your jets up a size or two. You can try just changing the needle position and idle air screws at first, but the '78's were tuned lean to begin with so I think you will probably not be able  to richen the mixture up enough with that alone.
Make your changes incremental, that is, don't change to many things at one time. And learn how to do a plug chop (search the forum, there are several threads on how to do it).
« Last Edit: May 12, 2014, 10:20:20 AM by Bankerdanny »
Offline DaveBarbier
« Reply #6 on: May 12, 2014, 09:25:46 AM »
Ok, plug chop, that doesn't seem too difficult. I think I have a decent stretch of road with a commuter lot for that.
Have any good resources for jets that won't break the bank? I'm assuming you guys get a few different sizes all at once then start experimenting.
Before each plug chop do you always put in new plugs? Even if I'm doing like 10 plug chops? Seems like that can get expensive, ha.
1978 Honda CB550K
Offline Gman
« Reply #7 on: May 12, 2014, 10:15:39 AM »
Dibs on the exhaust.  If/when you decide to part with it, I'd be very interested.
With that said, be judicious in a) messing with a great running bike, b) parting with your exhaust on the chance you want to revert to stock.
G
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
Offline DaveBarbier
« Reply #8 on: May 14, 2014, 04:41:45 AM »
G
I hear you, if it ain't broke don't fix it. But this can also give me time to learn hands on. I was one of those kids that took apart my fathers electronics and broke them and almost burn the house down.
And I will definitely be holding on to the exhaust for a little while after I get this rejecting and tuning done, just to be sure. But after that I'll ship it out.
1978 Honda CB550K
Offline DaveBarbier
« Reply #9 on: May 14, 2014, 04:42:31 AM »
Anyone else have a similar setup as I'm planning on doing that has experience that could potentially get me in the right ballpark?
1978 Honda CB550K
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #10 on: May 14, 2014, 05:17:41 AM »
You won't get a quick fix. You have to experiment! Bankerdanny said it already.
--Evan
1975 CB750K "Rhonda"
Offline DaveBarbier
« Reply #11 on: May 14, 2014, 06:52:18 AM »
Ok, so just to be sure, what I'm ultimately looking for is no flat spots while accelerating and the plugs to be a light brownish toast color, right? My thoughts with not going to pods but rather utilizing the plastic "plenum" is that I won't have too far to go, as far as tuning goes. At least that what I've heard from a few people.
I've only rebuilt one set of carbs before so I need to do research on what exactly I'm supposed to change and why. On to the internets I go.
Thanks
1978 Honda CB550K
Offline jamesbekman
« Reply #12 on: May 14, 2014, 07:04:25 AM »
Dont mess with anything.  Just some gas treatment in to help clean out the carbs since its running good, plenty of people here will tell you what to use to combat the ethanol in our gas...  The only thing I would mess with is what you are doing and is what I want to do myself, disconnect the air fliter housing and run a single K&N air filter in the oval hole.  Im not sure what that bracket is going to do that you designed but I would like to hear and see how it goes for you.
Again...  Dont touch the carbs.... DONT touch the carbs.... Dont touch the carbs....
If you want more power get another bike, or buy a spare engine and build it while you ride your bike that runs good...
Offline DaveBarbier
« Reply #13 on: May 14, 2014, 07:39:18 AM »
I'm essentially going to run a single K&N in the oval hole, but without the airbox around it. So it won't have as much restriction. The bracket will just interface the filter to the oval hole.
Are you saying don't change the exhaust either? Or change the exhaust but don't do any carb stuff?
I'm not looking for more power but instead a bike that I think looks "cooler". That's why I got the bike to begin with. Something to customize and make my own so I can be proud and have fun while learning more about bikes. I know there are two types of people here: go ahead and learn and try things out. And the other: don't mess with it, Honda did way more engineering and figuring out than we could ever do and they came up with this, so best not to change it.
I'm of the first mind set. Always have been, always will be. Not to say I don't like stock. I have a stock restored 74' CB125 that I love. But this 550 is a toy project.
Thanks for the insight, though. I seriously do appreciate it, but I am going to respectfully not heed your advice. Gods didn't make this bike, just people. And I am a person. I'm going to try and learn by doing.
Thanks
1978 Honda CB550K
Offline jamesbekman
« Reply #14 on: May 14, 2014, 08:03:13 AM »
Basically, cosmetically... do whatever you want.  If the bike is running fine, let it be that way till you finish everything else, then mess with the carbs if you would like.  When you do get to the point of making changes mechanically, change one thing at a time, then run the bike for alittle while, then change something else after a while and see how it responds etc...
Its easy enough to put on a different gas tank and put a cafe seat on the bike...  If you are looking to change the looks id start there and learn about what all that entails.  Maybe have a go at painting her yourself, thats a whole rabbits hole in itself you can go down...  Fitting a fiberglass tank... that in itself poses some questions on just how are you mounting the dang thing etc....  Where are you going to hide the electrics on the bike, where are you going to get the wire for the electrics(do you want the wire coloring to match? can you solder etc), are you going to rewire anything or just extend the wiring to be able to have enough length to tuck it under your cafe seat...  where are you going to mount the battery?  Those nice shiny pictures on the internet are photoshopped, ever see a battery in those really cool ones?  You have to have a battery to run our bikes, just cause its kickstart doesnt mean a thing.  Where abouts are you going to put that battery if you are trying to go for the look you are going for?  Turn signals?  Tail light?  These are things you should be looking into first before ever messing with those carbs...  Just loosing weight on the bike is going to make the bike go faster....  Alluminum rims will reduce weight as well making your bike "faster"  I would look into those things first then get into looking into jetting your carbs and further tuning...  When you do get to that point, expect to not get it right over and over and over again and realize that you are learning every time you fail.
« Last Edit: May 14, 2014, 08:06:16 AM by jamesbekman »
Offline Bankerdanny
« Reply #15 on: May 14, 2014, 08:20:59 AM »
The tuning issue with pods is partially due to the lack of velocity stacks, which results in inconsistent airflow that can be difficult to tune for. Adapting the K&N to your existing airbox (which others have done as well) solves that issue.
I don't think that the K&N by itself will flow enough additional air to necessarily require richer jets and that brand of header by itself also doesn't usually require changing jets. However, the two combined plus the already lean setup of the stock carbs likely means a jet change.
Offline DaveBarbier
« Reply #16 on: May 14, 2014, 04:30:27 PM »
I totally know what you mean. And I'm pretty much there already. I built a custom leather seat, stripped my tank, altered the frame, fitted all LED's minus the headlight, cleaned all electrical connections. I'm going to change the battery over to a smaller lithium ion Shorai in the near future and mount it somewhere. I don't mind having it exposed.
The REAL reason other than aesthetics for doing exhaust and intake is that after that I can remove the side covers, which will make the bike significantly thinner. I'm only 5'5" so that'll make it easier to "taxi" the bike around my dirt driveway and parking lots. That was also the reason I made my custom thinner seat, so I would be closer to the ground.
I appreciate the knowledge drop. I don't think I'm reckless. I'm a Swede and we tend to do things more methodical, haha.
Thanks
1978 Honda CB550K
Offline DaveBarbier
« Reply #17 on: May 14, 2014, 04:35:23 PM »
That's what I was thinking. Would it be horrible to just throw that stuff on and see what happens before a jet change?
I need to learn more about carbs and why we change jets to try and figure out what I need to do. Right now it feels like a shotgun, just throwing jets at it until it runs well. I wish there was a calculation I could do to get close.
I'm sure there's something written by Two Tired or Hondaman on here that can answer a lot of my questions. Just a matter of finding it.
1978 Honda CB550K
« Reply #18 on: May 14, 2014, 07:29:40 PM »
The pod change reduces the amount of fuel delivered by the carbs.  Carb fuel delivery works on pressure differential, and if nothing else, shortening the duct between inlet and carb throat brings the pressure closer to what is impressed on the top of the fuel in the float bowl.  Less pressure differential = less fuel flow.  The air restriction difference, pods to air box, is an imaginary myth for RPMs outside of 1000 rpm from red line.  The pressure difference is very real though and why jets must become larger to restore the fuel volume delivery.
That said, the pressure drop characteristics across the filter membrane can easily vary from pod design to pod design.  If you know the pressure drop comparison between the stock design and the design being installed you might be able to approximate what needs to change regarding fuel delivery orifices.
The stock 4 to 4 exhaust has a little back pressure, which is useful for idle mixture settings.  But, there is only one reflection source (from the baffle) per each cylinder.
A 4 into 1 reflects pulses back to all the other carbs, fouling their exit flow for all RPMs other than at a narrow band (near or at red line).  If they are properly tuned, the pulses reflect back at the designed RPM to reverse pack some fuel air charge into the cylinder's exhaust port, allowing a power boost with the proper carb jetting to compensate for the altered mixture.  At any RPM other than what the 4 into 1 is tuned for, the exhaust scavenge effect is ruined completely, making the cylinders fire even more inefficiently, and somewhat unpredictably.
At idle, back pressure helps hold some of the unburned hydrocarbons in the chamber. This allows leaner carb delivery.  Take away the Back pressure and the jetting that worked well before now needs enrichment.  This is why race pipes work like crap on the street where low and mid range operation is dominant.  The only exceptions I know of are the stock F model pipe and mufflers.  These are quiet high pressure pipes that work really well on the street, but are almost certainly down on comparative power at or above red line.  (wish I had a dyno)
Race pipes can work well on the track where the operational RPM band is limited, and the engine is expected to be refurbished frequently due to the routine flogging.
Pods and loud pipes may be a convenient style statement for artists and rebelious interests.  But, the physics and scientific principles are constants and spit in the eye of art projecteers that still need their art subject to function as well as before the stylistic massaging of functionally integrated components.
Ideally, you'd learn how and why the currently working system functions before making alterations which change things you never previously monitored.  Only then can you make changes that might follow a predictive outcome.  Of course that's a lot more boring for many than just changing things whimsically to see what happens.  But, be prepared for "ripple effect" where one change leads to another and then another to compensate for the previous change.
But then, aren't artists expected to suffer for their art?  (as well as remain impoverished.)   ;D
Maybe that's why I generally ignore aesthetics in favor of functionality.  :-\
Think I'll go for a ride.... ;D
Offline DaveBarbier
« Reply #19 on: May 15, 2014, 04:57:12 AM »
Any idea which 4-1 headers I have then? Curious if these ever came stock on the 550 or if the PO bought them somewhere else. What I gathered by this paragraph is that a Honda stock 4-1 will be better for the street than a different "race" 4-1. And possibly...dare I say easier to tune? Or at lease give better results. Although maybe not because I'm changing the muffler from stock...
Any other advice for a starting point as far as jets go or the above posts are as good a place to start as any? I know you wouldn't do this at all, but if you could imagine you were a suffering art projecteer you'd do what? After a little wax poetic, that is.
Thanks! :)
1978 Honda CB550K
Offline DaveBarbier
« Reply #20 on: May 15, 2014, 06:27:44 AM »
Looks like a Mac or Kerker. For carbs with pods and 4:1, try 105's. Get several sets of plugs, make certain the battery and points, and timing are perfect before you begin.
Vacuum synch the carbs after each jetting change to insure optimal testing. And be ready for plug chop after plug chop after plug chop after... Don't waste time withing to save and re-use sooty plugs. Replace and get the very best reading you can.
But be certain bike is otherwise running perfectly to minimize chasing your tail.
Would you say 105's even if I'm not using pods? If you see the first post I have a picture of what I'm using...a K&N filter adapted to the plenum which feeds the carbs.
And do I not need to change the slow jets (aka idle jets?)? All I would possibly have to change would be the main jets, needle positions and idle mixture screws?
Similar to this intake setup.
1978 Honda CB550K
Offline Lostboy Steve
« Reply #21 on: May 15, 2014, 06:38:52 AM »
Thanks
1978 Honda CB550K
That seat looks really nice!
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline DaveBarbier
« Reply #22 on: May 15, 2014, 07:53:48 AM »
Thanks! I think so too, ha. I've done some other leather work but building a seat was foreign and fun.
1978 Honda CB550K
Offline DaveBarbier
« Reply #23 on: May 15, 2014, 08:02:37 AM »
Ok, so I JUST noticed that the carb bowls are different. 1 and 2 don't match 3 and 4. There is a little spout where the hoses connect which isn't on the others Not sure how I missed this. I checked and all carbs are the same PD46C. Is this normal? The PO didn't mention changing anything but now I'm not sure. Could just be different float bowls.
I'm thinking of opening them up and cleaning and putting back to stock if they're not already before doing any rejetting. Bad idea considering it seems* to run fine as is?
*Maybe I'm nit picking but I might feel a slight hesitation right off the line.
Where are some good resources for my bike for rebuild kits and jets? I can't seem to find any yet for my specific year. Only up to '77.
1978 Honda CB550K
Offline Bankerdanny
« Reply #24 on: May 15, 2014, 09:31:38 AM »
Someone put the wrong bowl on carb 2. the 1 and 2 carbs (from left to right sitting on the bike) should have drain screws facing left. The 3 and 4 carbs should have drain screws facing right. Having a 3-4 bowl on your #2 carb won't impact performance, but it will make it more difficult to drain the bowl.
