Author Topic: CB550 - Issues for beginning rider - Help please!  (Read 29863 times)
Re: CB550 - Issues for beginning rider - Help please!
« Reply #150 on: June 05, 2014, 12:28:37 PM »
Stock jet's have a number stamped on them.
The needle should fall out of the slide pretty easily, where you can determine the E clip location.  Look closely, and you should also find a number/stamped marking.  You/we need to know this number. S/B 272304 or 273004 (Keihin numbers)
If it is not Keihin, then measure the needle.
Measure the over all length.
Measure the fattest diameter.
Measure the diameter at the tip, then at 1mm intervals up the taper until you get to the fatest diameter.
lookin' good so far...
Offline Koonendez
« Reply #151 on: June 05, 2014, 01:01:49 PM »
Thanks TT...
So I was putting the whole thing back together and saw your post...damnit...disassembled it again, and have the slide out but now I'm at a stand still as I need to somehow figure out how to get this stripped screw out of the slide now in order to take out the needle and measure.
Have to go to work....if you guys have any good suggestions on how I can pull this screw out let me know and I'll get back on it tomorrow morning.
Thanks for all the chiming in guys. Also another thing...the gasket set comes with A LOT of O-rings, but I can't seem to figure out where each of them goes. And when I know where an O-ring is needed, I can't figure out which one to use. The diagrams only help so much.
'78 Honda CB550K
Offline Koonendez
« Reply #152 on: June 05, 2014, 01:07:06 PM »
The main jet I don't believe is stock. It has an imprint that says K 1.8 on them.
'78 Honda CB550K
Offline Deltarider
« Reply #153 on: June 05, 2014, 01:54:20 PM »
Isn't that the floatneedle seat?
« Last Edit: June 06, 2014, 05:37:44 AM by Deltarider »
CB500K2-ED Excel black
Offline Koonendez
« Reply #154 on: June 05, 2014, 02:17:04 PM »
Ok clearly I need to spend a little more time with these carbs before I can start identifying them
'78 Honda CB550K
« Reply #155 on: June 05, 2014, 03:03:35 PM »
Probably the float valve seat.  Main jet sit in the body to support the emulsion tubes.
Cross head screws are pretty intolerant of the wrong cross head driver size.  I believe that is why many curse the screw as they have failed to provide the correct driver, or use a driver that has long since worn out.  Allens forces the use of the correct driver.  So, for many, this becomes a cure-all for their own lack of discipline, imo.
Anyway cross head rivers must fit in a way that they completely engage, the screw head features and with enough pressure to never let them "cam-out".  Philips was originally introduced in production to prevent unskilled workers from stripping threads, as it was easier and cheaper to extract a buggared screw head than repair stripped threads in the parent body.
Offline SohRon
« Reply #156 on: June 05, 2014, 09:15:02 PM »
Just logged in to this thread for the first time and it sounds like you're getting some good info. Sorry to hear about your tank, especially since it appears you may have decided upon an acid treatment after reading my build thread. The Prep & Etch worked well for me, but I only left it in for two hours, not two days... If I had seen this in time I certainly would have cautioned you against leaving it in your tank for that long. I'm not surprised that you developed problems, although the pinhole was probably already there and the tank treatment just uncovered it...
In this, as in everything, be sure to follow procedures as they're presented for the best results!  :)
Good luck with your project.
Offline Koonendez
« Reply #157 on: June 05, 2014, 09:34:17 PM »
Thanks for joining in SohRon. The tank was corroding there anyhow and if anything the process showed me damage I wasn't aware of. Tank is welded back up and going through a Metal Rescue treatment while I continue battling the carbs.
'78 Honda CB550K
Offline SohRon
« Reply #158 on: June 05, 2014, 09:57:57 PM »
Good to hear it!   8)
Offline Koonendez
« Reply #159 on: June 06, 2014, 07:10:41 AM »
Victory! The stripped head FINALLY came out this morning!
So TT...here's the info on the slide needle.
#272304
Clip is on 5th notch from the top
1.25" from tip to fattest diameter
Considering I am running a 4-to-1 exhaust with very, very little back pressure and reverting back to stock air box (or closest I can get to it), what clip setting should I set this needle to? Until I hear otherwise, I am going to move the needle position up to the 4th groove from the current 5th setting and give it a try.
Jet Sizes:
Main Jet: 120
Slow Jet: 40
Valve Seat: 1.8
Throttle Valve: 2.5 / 103
« Last Edit: June 06, 2014, 08:51:43 AM by Koonendez »
'78 Honda CB550K
« Reply #160 on: June 06, 2014, 09:55:29 AM »
If you can use a stock air box, even with a UNI foam filter, the 4th groove should be ok.  I expect the main should be 105 or maybe 110 at the largest.  To restore proper throttle response, you will have to fine tune the max # of turns out from seated that will still net you reliable power with up to 1/2 remaining throttle twist.
These recommendations are just a prognostication.  The only real way to zero in on proper set up parameters is with either a dyno, or test track runs with plug reads to indicate combustion parameters consistent with present changes.  The bike ain't gonna adjust itself.  And, that is simply the price you pay for running non-stock.
FYI: The needle is a standard K needle.
For the record, my measurements for this needle are:
Jet Needle and taper (Throttle valve)   #2.5 - 4th groove
Jet needle number   272304
Jet needle OAL                          5.57cm
Jet needle diameter at tip          1.25mm
Jet needle diameter at 1mm   1.63mm
Jet needle diameter at 2mm   2.06mm
Jet needle diameter at 3mm   2.49mm
Jet needle diameter at 4mm   2.52mm
Jet needle diameter at 5mm   2.55mm
Needle jet orifice                   2.60mm
Offline Koonendez
« Reply #161 on: June 06, 2014, 10:57:13 AM »
Awesome. Going to finish the rest of the carbs and set clip on 4th groove. In the meantime I'll look around the boards to see how I can retrofit a stock airbox with a uni filter. Thanks for the help TT and everyone else that chimed in.
'78 Honda CB550K
Offline Koonendez
« Reply #162 on: June 06, 2014, 11:00:12 AM »
Is there a diagram somewhere that can show me where all these orings belong? Does the gasket set come with extra o rings in each set? There are much more orings in the set than I see in my carbs
'78 Honda CB550K
Offline Deltarider
« Reply #163 on: June 06, 2014, 12:19:10 PM »
There are two (at least) ment for the T-joint between the carbs (where the fuel tube is connected)
« Reply #164 on: June 06, 2014, 12:37:20 PM »
Each fuel inlet tee gets 4, two on each side of the Tee.  And of course, there are two tees.  If you don't separate the carbs and they aren't leaking, probably just leave them alone.
There will be extra of these, because if you separate just one carb from the bank you need 4 orings for both sides of the fuel tee connection.  If you have four carb gasket sets, there will be two extra of these in each set.
The smaller fat one goes on the drain screw.  That should leave one for the main jet and one for the float valve seat.  I recall the smallest one goes on the main jet.  It's been a while, though.
Offline Koonendez
« Reply #165 on: June 16, 2014, 07:15:47 PM »
Alright guys, carbs have been cleaned and reassembled with clip position moved up to 4th position.
These are the only components I've gathered together from eBay along with my own stock parts. I don't have any of the hardware or foam element pieces. Can I get this airbox to work with what I've got?? Thanks in advance.
Koon
'78 Honda CB550K
« Reply #166 on: June 16, 2014, 07:50:17 PM »
Pretty close.
Do you have the other L bracket for the filter box top mount?
Any hoses?
Foam for the oil separator?
Did you get the collars that keep the plastic from compressing between bolt connections?
Is that plenum for an F bike or a 77-78K model.  The rubber couplers are different.  Same goes for that air horn.  The screen plate at the entrance is slight different size.
I'd get a new filter element.  From economy use the UNI NU-4055.  But, the stock ones work great.
Offline Koonendez
« Reply #167 on: June 16, 2014, 08:59:49 PM »
Seems like there's a lot I need to scrap together. I think I'll just put pods back on for now until I can manage to get these specific bits. I've searched eBay and can never find the parts I'm missing like the brackets and hardware along with foam element pieces. Frustrated.
'78 Honda CB550K
Offline Koonendez
« Reply #168 on: June 16, 2014, 09:02:10 PM »
Don't have the L bracket. I have a breather hose. No foam. No collars. The plenum is from a 77-78 K model.
'78 Honda CB550K
Offline Koonendez
« Reply #169 on: June 16, 2014, 09:24:06 PM »
Hey TT any suggestions on bench syncing these carbs before I set them back on the bike? I assume the light method is the best option but if I'm putting pods back on for now, what should they be set at?
'78 Honda CB550K
« Reply #170 on: June 16, 2014, 11:19:28 PM »
Filtration has no effect on carb vacuum balance.
Offline Koonendez
« Reply #171 on: June 17, 2014, 08:09:32 AM »
Plugs I am replacing. 1-4 left to right.
'78 Honda CB550K
Offline Koonendez
« Reply #172 on: June 17, 2014, 09:44:56 AM »
Does anyone have a picture for correct throttle cable routing? I have done a search and can't seem to find one. Thanks
'78 Honda CB550K
Offline Koonendez
« Reply #173 on: June 17, 2014, 11:23:28 AM »
Ok I've got cables installed but I'm certain something is wrong as it is very difficult to get WOT and the pulley is barely moving.
This is also embarrassing but I can't figure out where my fuel lines should be entering the carbs. Of course I didn't take a picture and the clymer is pissing me off. Please help this hopeless guy. Thanks
'78 Honda CB550K
Offline Koonendez
« Reply #174 on: June 17, 2014, 11:27:39 AM »
Found fuel line ports. Ughhh.
'78 Honda CB550K
