Author Topic: CB550 - Issues for beginning rider - Help please!  (Read 25297 times)
Offline goldarrow
  • one day, i'll be an
Re: CB550 - Issues for beginning rider - Help please!
« Reply #100 on: May 21, 2014, 01:13:29 PM »
Fuel tap, fuel valve, petcock, all mean same thing.  Fuel filter goes over on the long plastic tube.
CB550 K0
« Reply #101 on: May 21, 2014, 01:22:07 PM »
Varying degrees of success.  I got one out with an easy out.  I also got one out with a close fitting machine screw sort of "tapped" into the soft nylon.
The fuel filter comes straight out of the hole.  Rusticles that have grown into the soft nylon can bind it in there as good as glue.  And anything that makes the nylon expand outward also increases retentive friction.   Extraction is a balanced effort to grab but not so much as to wedge the filter sleeve into the hole.  Insertion has never been an issue.  The nylon lasts forever unless physical damage has occurred.  These come out easily in like-new tank bungs.
I had one tank so rusty, the filter sleeve came out in pieces.  I was still sad I couldn't save it.
Here's what they look like.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #102 on: May 21, 2014, 02:24:14 PM »
Putting the new one in is the easy part, just slide it over the tube and screw the assembly back in place, the petcock will push the screen up where it need to be.
Getting the old one out can be a challenge, I recall that I used an awl to get my old one out on my '77 K back in 2011.
« Reply #103 on: May 21, 2014, 04:51:17 PM »
Isn't there a flatted side to the screen/tube?  Or, is that just the 75-76 models?  I can't find my stash right now.  ::)
Anyway, if it has the flat, that must be aligned first during assembly.
Offline Koonendez
« Reply #104 on: May 21, 2014, 09:26:14 PM »
Well came home from to rotate my tank with the P&E and found this...
Pretty upset right now and trying to think that maybe I can get the hole welded shut as I don't want to set aside money for a brand new tank just yet. It was definitely on my list of things to do but way down the road. Any suggestions? It's dark as heck outside so I'll have to examine the tank better tomorrow afternoon
'78 Honda CB550K
« Reply #105 on: May 21, 2014, 09:33:15 PM »
I'd buy a brand old tank.
Offline goldarrow
« Reply #106 on: May 21, 2014, 09:53:36 PM »
Don't you have one like his to sell?
CB550 K0
« Reply #107 on: May 22, 2014, 12:31:27 AM »
That's what acid does to metal, it eats it away.  And, it's why I prefer the electrolysis method about which has been posted many times.
How long was the acid left in tank?
Still, if you are going to patch the holes, brazing is far easier than welding.
Offline trueblue
« Reply #108 on: May 22, 2014, 01:24:28 AM »
I lead soldered my tank over 3 years ago now, still holding nicely.  I used a large electric soldering iron, about 1" in diameter, some plumbers solder and bakers soldering flux.  Soldered it up then sanded it back to shape, some of the holes in mine were up to 1/4" in diameter after it was cleaned up.  You want to keep flame away from the tank at all costs.  ;D
1979 CB650Z
Offline Franky
« Reply #109 on: May 22, 2014, 03:41:14 AM »
I love that you guys are helping out Koonendez so much - even to the point of telling him how to unscrew the throttle cables :-)
You rock!
1974 Honda CB360T Stock
1974 Honda CB550 K0 Stock
1977 Honda CB550 K3 Cafe - never ending build :)
1988 Honda Dax ST50 Cafe
1997 Honda Benly 50S Stock
Check out my "Yamaha R6 fork on a CB550 made easy" thread:
http://forums.sohc4.net/index.php?topic=118983.0;all
« Reply #110 on: May 22, 2014, 05:44:28 AM »
I do have a 550 tank with original paint but it needs PDR before going up for sale.
Offline Maurice
« Reply #111 on: May 22, 2014, 07:07:31 AM »
Soldering would be best. I have had luck with POR-15 inside the tank to seal a pinhole. Acid for de-rusting is a PITA as it flash rusts almost immediately, the gift that keeps on giving...
Offline Koonendez
« Reply #112 on: May 22, 2014, 09:40:43 AM »
Update: Came out this morning and immediately removed the E&P. Rinsed inside of the tank with hot water and baking soda. Rinsed the tank with Acetone and fogged the tank with WD-40. Inspected the leak and found the hole. It is literally the size of a pin hole. Tried soldering it but having some trouble getting a good seal. For now it's plugged up enough to keep air out but definitely not a permanent fix. Good for now while I work on carbs.
'78 Honda CB550K
Offline Bankerdanny
« Reply #113 on: May 22, 2014, 01:50:45 PM »
A competent radiator shop should be able to solder up a pinhole for you.
Offline billingstitan
« Reply #114 on: May 22, 2014, 07:42:49 PM »
I've got an old cb550 tank with the same paint that had pinholes that I used a combo of caswell's dragon red epoxy and sealing putty to seal up until I got the rest of my bike straight. Opinions vary on sealant, but I've had great luck both times I used it (with very careful attention to prep).  It's been several years and still in good shape (see pic).
That kept me going for a year or so until I could find a good used tank for reasonable that was worth painting. Those can be tough to find at a decent price. I managed one for under $100 though. Used a rattle can and aftermarket decals and IMHO it came out amazing (see pic - tank's a bit dusty, but you can get the idea) - you can get good paint here: http://www.repaintsupply.com/pd_2_part_2k_aerosol.cfm
I've also got a spare 550 tank (see pic) that I got in my searches for a solid tank that ended up having some bondo on it after I got all the paint stripped :-(  But it's in good shape w/ no internal rust. I'd let either of those tanks go cheap if you need one. PM me if you're interested.
That said, you could prob do just as well getting some sealant and putty since you've already gone through the effort to strip and etch the interior. Caswell's is the only one I've ever tried -
Calling upon my years of experience, I froze at the controls.  ~Stirling Moss
2014 Ducati Monster 796
1977 CB550K http://forums.sohc4.net/index.php?topic=138289.0
1977 CB550K
1972 CL175
2000 Kaw Nomad 1500
1992 KDX 200
2001 Honda 80R
Past Bikes:
1973 Kaw 900Z1
1970 Yamaha 350RD
2003 Yamaha VStar 1100
2001 Suzuki GS850
Offline Koonendez
« Reply #115 on: May 23, 2014, 07:28:51 AM »
Thanks guys. Just curious about the Caswell Sealer...Will the epoxy stick and work properly even with some minor flash rust already existing in the tank or do I need to completely remove all rust before sealing?
'78 Honda CB550K
Offline Koonendez
« Reply #116 on: May 23, 2014, 08:51:09 AM »
Awesome. I'm going to listen to TT and insect the tank when I get some time tomorrow morning and try to remove the in tank filter first and foremost. I have no idea how in the world to remove anything out of that little hole but will do a search in the forums to see what people have used to get it out. I imagine pliers will not be the only tool I need.
Then I'm going to check the inside of the tank to see if my treatment did anything to remove the rust inside. Think I'm going to go the route of Caswell sealer inside as the last step just for future preventive issues with rust. I live in Chicago so humidity and dry cold pretty much plagues us all year round.
'78 Honda CB550K
Offline Koonendez
« Reply #117 on: May 23, 2014, 08:58:00 AM »
One thing I want to mention before I start tearing down these carbs are any weird tools I'll need that will help me with the rebuild. I've got a short list so far including...
Sewing needle to push out emulsion tube
Feeler gauge to bench sync
Small magnet for screws inside sleeve
Float level tool (suggestion for best one to use??? I don't have this yet)
Chem Dip from Berrymans
Pine sol to soak bodies
Other then the float tool which I need to order ASAP is there anything else I'm missing? And which float tool have worked best for you guys in the past?
'78 Honda CB550K
« Reply #118 on: May 23, 2014, 09:14:32 AM »
Caswell's is designed to work with some rust in the tank (obviously not flaking-type rust - flash rust is fine and so is pitting). The biggest thing is to ensure your tank has been thoroughly cleaned and is dry as a bone.
+1 on the acetone - that's what I used as the final rinse after scrubbing my tank with nuts and bolts (put those on a loop of wire or coat hanger, as they can be tough to get out - ask me how I know).
When finished with the acetone wash, set it in the sun and stick a heat gun or blow dryer in the fuel opening and run it at the LOWEST, setting for about an hour until it's perfectly dry (hair dryer's worth of heat AT MOST - even cool works, just need some air circulating through the tank to speed evap) .
Once you're positive it's dry - set it out again in the sun for the afternoon just to be sure. You do not want ANY moisture in that tank before you apply the caswell's.
Prep is where most people fail with the caswells. I used the hardening putty underneath the holes for insurance, although I'm not sure that was even necessary. You can pick that up from Caswell's as well, or at any autoparts store. It's a two-part putty. Just knead the two putties together and press it under those pinholes - you can paint right over it after it cures (apply AFTER you've applied the tank sealant and it's cured).
I do have a caswell's kit that I'm selling - I had planned on sealing the tank I painted, but ended up getting one with zero rust so did not need to use it. Those tank sealers are an awesome resource when you're in a pinch with a rusty tank or one with pinholes - but I would not ever recommend anyone use them on a tank that doesn't have rust as the prep is a b**tch and if they do fail it's a nightmare. Anyway, I will make you a deal on that caswell's kit I have if you're interested (PM me if so), or just go to caswell's and order the dragon red kit - they run about $55+shipping last time checked.
I've used both the regular and the dragon red - I found the red dye was very helpful so you can see the liner with a flashlight as you apply it to the inside of the tank -- it's thick like the consistency of honey when mixed, and you have to do a lot of spinning and turning of your tank to ensure the inside is totally coated.
Basically wrap your tank in saran-wrap, use some duct tape over that near the fuel hole and bung hole - and also cover the pin holes with duct tape -- you apply the patching putty (if you choose) AFTER the Caswell's. When your prep is done, mix up the epoxy - and once it's applied to the tank, it's a good idea to clean that old fuel filter real well, and then use that to poke through the petcock hole if needed to ensure the caswells doesn't plug that hole (don't leave it in there - just use it to clean out the hole if needed). I just used a black rubber cork in the petcock hole and let the caswell's set, then pulled it out and there were no issues with plugging.
I've had nothing but success using it - but I have heard of a few bad experiences with it - whether it was bad prep or not, I can't say. I did a TON of research before I did my tanks, and Caswell's stood out as the most reliable - but again, opinions definitely vary. I am partial to the two part epoxy concept. If you drip or splatter, clean immediately, because that stuff hardens and it's not coming off of any parts once it's set.
« Last Edit: May 23, 2014, 09:18:31 AM by billingstitan »
1977 CB550K
1972 CL175
2000 Kaw Nomad 1500
1992 KDX 200
2001 Honda 80R
Past Bikes:
1973 Kaw 900Z1
1970 Yamaha 350RD
2001 Suzuki GS850
« Reply #119 on: May 23, 2014, 10:58:27 AM »
If you meant plastic tipped knitting needle, that will work.  But, a wooden dowel or nylon rod would work, also.  The end of the tube you will press upon is a jet orifice, which you do NOT want to distort.
I'm not sure how that would work, most use a drill bit.  But, even that is fraught with possible problems, particularly with the 76 and earlier carbs.
Handy tool yes and they have their place.  But not essential, or of much help when installing the screws.  Go to the stationary store and get some glue dots.  These are gummy stickys globs  that you can put on the end of a small dowel or the end of your cross head screw driver for both extraction and installation.
Just why do you need to remove the slides anyway?  Are they sticking to the slide bores?  You have a yen to dismantle in a quest for total domination over the machine?  You'd be better off learning what the bits do and go after the ones that are uncooperative, imo.
Cut one out of a plastic card.  Make legs that span the bowl landings, and cut out the center to the 22mm depth.  Or, just use a machinist's pocket scale.  See pic.
Your call, if the carbs are really crusty gunky.  But, mostly not necessary and overkill.  The only reason to separate the carb from the tie plate is to replace the fuel tee seals, or paint/polish the carb bodies, imo.
You can clean all the essential bits needed to make them work well, with aerosol canned carb cleaner.  It's mostly the pilot system passages you need to "prove" will flow, anyway.  Reliance on a "soak" to get those pathways clean is a neophyte's mistaken assumption, imo.
EGADS no.  It has a pH of 2-3, acidic.  Battery acid is pH 1.5 or lower.   Yes mixing/diluting it with pH 7.0 water will lessen the acidity.  But, carb cleaners are purpose built for the carb cleaning task and will NOT harm the metal parts of the carb.
 Save the pine sol for the kitchen floor.  It was never intended to clean carbs and is only favored by the "cheapies" who found some in mom's cleaning cabinet.  Soak them long enough in this and they will etch metal off the carb bodies.  The slides are supposed to fit tightly in the bores.  Remove metal here and its like adding years of wear.
Yes.  The seal kits; one for each carb.  16010-323-315
Offline Koonendez
« Reply #120 on: May 23, 2014, 11:59:20 AM »
Billingstitan: thanks for the info. Just sent pm about the kit
TT: thank you so much for all the help you've already posted for me. I have happily returned many products or unnecessary tools/chem already from the knowledge of the members on this forum and continue to appreciate all the advice.
I will use my take out chopsticks instead of a kitting needle. Will look again at what to do to sync the carbs instead of the feeler gauge method. I plan on installing stock airbox when putting carbs back on assuming I can find the rest of the parts needed before then. I was assuming I needed to break down the slides in the carbs to clean the slide needle? But if it's not necessary woo hoo! Less breaking down the better for me. All I have for reference on cleaning carbs so far is that video I posted and that guy doesn't seem to know what he's doing. Wish you had a full video on YouTube showing what you do step by step. The float level tool will be a challenge for me but will give it my best to make something using that picture you posted. Returning chem dip and will not go though the pine sol route. Thank you! Will order seal kits asap.
'78 Honda CB550K
« Reply #121 on: May 23, 2014, 04:00:45 PM »
Bench sync using light method:
http://forums.sohc4.net/index.php?topic=13937.msg12199#msg12199
You might need to remove the slides to push out the emulsion tubes.  You do not need to de-rack the carbs to do so.  In fact, you don't even "need" to remove the carbs from the bike.  (Though doing so may make understanding the carbs easier.  And, if corroded, gummy, or krusty, easier to clean.)
I don't think I've ever seen a dirty slide needle.  But, I haven't seen them all.  And, the only practical way to determine their clip position is to remove them, unfortunately.
The aerosol spray cleaner will be used to prove the pilot circuit passageways are clear.  There are 4 access points to the pilot circuit: 1 - the pilot jet, 2 - the air jet (at the carb airflow entrance), 3 - the pilot screw bore, 4 - the hole feeding into the carb throat bore.  The fluid is used to flush and "see" flow from each of the four ports to each of the others.
More as needed...
Offline MandEms
  • MandEms
« Reply #122 on: May 23, 2014, 05:20:38 PM »
This is a good thread.  Thanks for going through it, Koonendez.  You're doing well.
I especially like TwoTired's light method for bench synching.  Makes sense.
Carry on.
Mark
Offline lucky
« Reply #123 on: May 23, 2014, 09:08:51 PM »
Thanks. I went to an auto parts store today but couldn't find a thin walled 18mm spark plug socket so I went to a Honda dealership and asked the parts department who told me they cannot order me any tools unless its for the use of the dealership.
Anyone know if Sears Auto centers will carry the parts needed? Also I am not familiar with that technique. Also, where can I find the spark plugs for these bikes? Would any auto parts store carry them? I will try and pull off carbs this Wednesday and get to dismantling them to the best of my ability. I assume I will need to remove the tank completely before I can pull carbs so I will empty the tank and look into a rust removal system and re-line the inside of the tank.
You really need to find someone in the area that has some Honda experience.
Japanese bikes.
The carbs if they have stock jets, will be running very lean.
The idle jets could be clogged and that is why it will not idle.
Also not having the choke on when it is cold on first start up of the day.
Sears cannot help you at all. Forget it.
Offline Koonendez
« Reply #124 on: May 25, 2014, 07:42:27 AM »
Hey TT, is there a another photo of your Float Level Tool that I can see in its entirety? Also, the Parts number you gave me for the gasket set...is that from Partzilla? Cause someone else gave me a link to get a gasket set but the part numbers are slightly different from the numbers you posted in the thread earlier.
16010-323-305 - This is the Gasket Set part number from Partzilla
16010-323-315 - This is the parts number you posted...Different site?
Found a local motorcycle shop that is welding my tank's pinhole for me. I've also got some Metal Rescue being shipped to me and I will be de-rusting the inside and outside of the tank immediately after it arrives. Then paint the outside to prevent any more corrosion. Going to work on carbs for the time being. I'll keep you guys posted on what the jet sizes and the conditions of each carb once I get them going.
« Last Edit: May 25, 2014, 07:45:17 AM by Koonendez »
'78 Honda CB550K
