Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
He means the shock "eye" not the stud on the frame, which is M10 thread, but the stud itself is bigger than that.I can measure it for you later today if nobody pitches in.
Are you looking for bushings? Honda still sells them.
Quote from: evanphi on May 13, 2014, 07:59:02 amAre you looking for bushings? Honda still sells them.No, to put a washer between the shock and the frame, there's a little bit of play there.
Quote from: mcswny on May 13, 2014, 08:27:10 amQuote from: evanphi on May 13, 2014, 07:59:02 amAre you looking for bushings? Honda still sells them.No, to put a washer between the shock and the frame, there's a little bit of play there.The washer goes on the outside of the shock, especially if you have no grab bar. You may be bottoming out your acorn nut? Part 15 here:http://www.cmsnl.com/honda-cb750k2-four-usa_model14362/partslist/F20.html#results Available here: http://www.vintagecb750.com/search/?q=shock (at the bottom).
