Author Topic: Cannot time cb550... Will not let me advance far enough  (Read 1268 times)
Offline dergs713
« on: May 13, 2014, 10:13:28 AM »
I am not able to time my cb550 properly. With a timing light I am still not able to advance my plate far enough. What could this be. I've gone thru everything i can think of. New points, new condensers, check springs, check plugs, plug wires, batt. Ect. Even #$%* I didn't think would matter I went thru again... Anything would help. The thing runs fine down the road, but I know is not at it's full power due to mainly the timing being off..
Matt
Offline iron_worker
Re: Cannot time cb550... Will not let me advance far enough
« Reply #1 on: May 13, 2014, 11:26:58 AM »
Are you talking about the base timing at idle or the full advance at ~2500RPM?
Some things that I have learned from my 750 and I'm sure most are the same on the 550:
1) Cheap points plate/points. Some of the aftermarket points arms are not constructed with the same geometry as the originals making it very difficult/impossible to time. Also some of the points plates suffer from the same quality control issues...
2) Loose fitting points plate: Even from the factory the points plate isn't a tight fit between the locating "studs" on the engine case. Shifting the plate side to side will affect points gap which in turn affects timing.
3) Worn rubbing block: sounds like you've addressed this with new points ... but what brand?
4) Binding/sticking advance mechanism: have you checked that the advancer is working smoothly and is greased up etc? I have heard of some people having to bend the stops out to allow more advance.
Some other thoughts ... condensers, plugs, plug wires, and battery should have no affect on timing.
IW
Offline dergs713
« Reply #2 on: May 13, 2014, 11:38:37 AM »
I actually have tried two different point brackets... And then a total of three different point sets and two different advance units. I have a parts motor so I've been swapping.. I'm starting to think maybe the cam chaine is off a tooth on the cam gear. But the bike seems to run ok up to 80+mph. No real coughing or breakup in rev. Matt
Offline Maurice
« Reply #3 on: May 13, 2014, 11:39:07 AM »
Didn't see it mentioned... Points gap has an effect on timing, try moving within the spec and see what it changes. HTH and good luck
Online Deltarider
« Reply #4 on: May 13, 2014, 12:02:12 PM »
In the 70s and 80s mechanics seldom adjusted the timing plates as practically all oftiming could be addressed by adjusting the points gap. Now that you've touched everything it's a must you start with adjusting the breakerpoints gap within spec as suggested above.
CB500K2-ED Excel black
« Reply #5 on: May 13, 2014, 01:34:34 PM »
the cam timing doesent affect the ignition timing,only the cams timing.
Offline dergs713
« Reply #6 on: May 13, 2014, 01:40:40 PM »
Gap is .013- .016 at its highest point right?
Offline fmctm1sw
« Reply #7 on: May 13, 2014, 07:08:21 PM »
IW
That has my vote.  Been there seen it..
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #8 on: May 13, 2014, 07:12:04 PM »
Have you looked at the ignition FAQ?
