Hi,
thanks in advance for reading.....just about to button up my crank cases - my first bike, my first build, my first engine tear down and rebuild. I REALLY do not want to have to open it all back up after all the hard work I've put into it. I did a "dry run" and put the bottom crank case on to the top, made sure to get centre gearshift fork between the 2nd and 3rd gears on the main shaft. Once together I tried to turn the gearshift drum to see if I could get it to turn/shift - it moved maybe an 1/16th of a turn. Is something wrong with the shifting or does it all have to be buttoned up completely, with the shift mechanism installed before it will shift properly?
Cheers
