Author Topic: Use K&L 4-Gauge Carb Synchronizer on Twin CB350?  (Read 1408 times)
Offline ironandtime
    • Iron & Time
« on: May 22, 2014, 12:53:04 PM »
Hi All - This is probably a silly question but I am not finding an answer anywhere. It involves a twin, but is still 4-cylinder related in a way. Can I use my K&L 4-gauge carb synchronizer to sync the two carbs on a CB350 twin? Whaddaya do with the extra two gauges/connections? Since the main goal is to just get the two carbs the same regardless of numbers, I thought I might still be able to use the 4-gauge unit. Thoughts?
1978 Honda CB550
Offline jamesbekman
Re: Use K&L 4-Gauge Carb Synchronizer on Twin CB350?
« Reply #1 on: May 22, 2014, 12:55:03 PM »
Yes
Offline jamesbekman
« Reply #2 on: May 22, 2014, 01:01:58 PM »
You can get away with just using a single vaccuum unit as well...  or use one of these or one of these....  http://www.mofoco.com/item/EMPI_5746_Dual_Carburetor_Sync_Adjusting_Tool_Vw_Carb/422/c64
« Reply #3 on: May 22, 2014, 01:09:10 PM »
Hi All - This is probably a silly question but I am not finding an answer anywhere. It involves a twin, but is still 4-cylinder related in a way. Can I use my K&L 4-gauge carb synchronizer to sync the two carbs on a CB350 twin? YES Whaddaya do with the extra two gauges/connections? Nothing...they just sit there looking at you...  Since the main goal is to just get the two carbs the same regardless of numbers, I thought I might still be able to use the 4-gauge unit. Thoughts?
each gauge operates individually so you can use any two of the four gauges....
Offline krusty
« Reply #4 on: May 22, 2014, 06:14:43 PM »
Find a buddy with a 350 twin and do two at the same time.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
  • I'm back
« Reply #5 on: May 23, 2014, 03:59:48 AM »
:D :D :D
« Reply #6 on: May 23, 2014, 04:03:46 AM »
or just suck on the other two free hoses?
Offline Rodger
« Reply #7 on: May 23, 2014, 04:25:37 AM »
LOL, all kidding a side you can just pick any of the 4 gauges and hook 2 up.  But there is no vacuum ports on a CB350.  Are we talking about syncing the idle? Because the throttle cable also need to pull both carbs at the same time too.  So the idle adjustment and cable both play a role and can throw the carbs out of sync.
69 Honda CB350, 71 Honda CB350K, 72 Honda CB350K Café,
75 Honda CB400F Blue, 75 Honda CB400F Red 73 Honda CL175 and 76 Honda CJ360
« Reply #8 on: May 23, 2014, 04:50:39 AM »
just make some,drill and tap a port.
Offline jamesbekman
« Reply #9 on: May 23, 2014, 08:44:00 AM »
Go old school and just use a rubber tube and put it in the carb inlet and put the other end to your ear.  Im not joking...
« Reply #10 on: May 24, 2014, 12:11:51 AM »
yeah some people don't get it?i like having a laugh and fool around mixed in with proper correct answers with photos etc,you wont find a better site than this one hands down!
