Logo merchandise is available at the SOHC/4 Shop
I did look at that and I shook the wires at the switch and at the plug where it connects and I could not get the light to go off and on.Any idea on what gives power to the bike to make it spark,as in you can turn the key on hit the starter and it turns over but no spark?I did find the wire where the bulb gets pushed into the cluster of dash lights if you move it around the light would go on and off? Sould the oil light bulb have anything to do with not starting?Thanks
